Stuart_B
posted on 18/5/09 at 06:29 PM |
fuel sender
hi all, i need some help, i have a koso dash to fit to my car, but the fuel gauge ohm setting's are 100ohm's or 500ohm's, but i have
a standard sierra fuel sender and the reading about 20ohms full and around 260/270ohms empty, so what can i do?
can i ad reistors insuch away, it will work or do i need a need sender unit to match the ohms reading of teh dash?
if resistor what size?
if new sender does anybody know of one i can fit?
thanks
stuart
omega0684
posted on 18/5/09 at 06:35 PM |
personally i would fit a new sender, one that is caibrated to match the dash, it will save a lot of hassle
Bigheppy
posted on 18/5/09 at 07:52 PM |
Could you not just bend the sender arm through 180 deg
Then see if your dash works
Adam
posted on 18/5/09 at 08:45 PM |
I fitted a sender from a black bird and works fine with the Koso gauges
Hope this helps
Adam
Stuart_B
posted on 19/5/09 at 07:45 PM |
hi all, does anybody know where the blackbird fuel sender enters?
i have my hole at the top will it work?
thanks
stuart
Adam
posted on 19/5/09 at 08:21 PM |
I fitted mine in to the top of my MK tank. Bit of bending of the float is needed but works fine.
Adam
Adam
posted on 31/5/09 at 03:51 PM |
Sorry Stuart got no pics just keep offering it to the tank, thats all i did.
Sorry i can't be of any help
Adam
Stuart_B
posted on 1/6/09 at 03:59 PM |
ok, thank you any way.
stuart
