<<  1    2  >>
Author: Subject: Datatool Digi Gear Indicator
cj440
posted on 12/9/15 at 03:09 PM Reply With Quote
I have a Westfield Megabird. I bought a Cartek Gear display with built in shift lights www.cartekmotorsport.com/CARTEKShiftLights.html .
Fitted it, programmed the display colour and the shift lights no problem, however I kept getting error1 displayed when attempting the gear display programme which means no speed signal. I had tapped into the speed sensor wire for the cars speedo which is not correct. I emailed Cartek for any advice (brilliant company by the way) and they emailed me straight back saying I needed to find the honda speed sensor wire which is normally pink. I had a search around & found the 3 pin connector which indeed had the pink wire. tapped into that & bingo, programmed no problem & works perfectly.
Hope this helps,
CJ.
He who dies with the most toys wins
<<  1    2  >>
