Author: Subject: ECU
JohnH
posted on 3/3/17 at 03:36 PM Reply With Quote
ECU
Just after a bit of help, I've got myself a Emerald ecu, but iam looking at getting the wiring harness to go with it, but iam not sure which harness would go with it. Iam building a Aries locost, with a 1.8 blacktop Zetec on injection. I was wondering if there off the shelf harness from the Westfield would fit mine ?
I have rang Emerald, but I think iam more confused now.......
View User's Profile View All Posts By User U2U Member   JohnH 's Yahoo
Daf
posted on 3/3/17 at 04:18 PM Reply With Quote
I used the generic loom from Emerald, I had to make some modifications to make it neat in my car like shortening some bits and lengthening others. You should be fine with the generic Westfield loom
posted on 3/3/17 at 06:24 PM Reply With Quote
Or buy the multi plug,connectors from Emerald and a load of different coloured wire and build your own custom loom. Make sure you make a note of which wires go where
JohnH
posted on 4/3/17 at 08:38 AM Reply With Quote
Thanks, I was hoping to get a full loom,as iam not good with wiring........ Cheers 👍🏻
Daf
posted on 4/3/17 at 08:41 AM Reply With Quote
If you weren't so far away I'd come help, I love wiring!
posted on 4/3/17 at 09:32 AM Reply With Quote
I hate wiring and electrics but still found wiring up my ECU straightforward. Also making your own loom means you don't have to chop or extend an existential nag loom
Badger_McLetcher
posted on 4/3/17 at 11:33 AM Reply With Quote
Unfortunately I think whatever loom you get will need some modification, so it comes down to what is easier - trying to modify an existing loom, or making a new one?
I made my own loo m as well. It's not too difficult once you get into it, you just need to take it slowly and check what you are doing. I found that zip-tie labels are quite useful for making sure the wires go into the plugs as they should.
If dysfunction is a function, then I must be some kind of genius.
JohnH
posted on 4/3/17 at 04:30 PM Reply With Quote
Thanks, might speak to emerald again to see how much the plugs are and see what making my own world be like. Thanks again 👍🏻
