<<  1    2  >>
Author: Subject: Bloody wing stays Grrrrrrrr
Johneturbo
posted on 30/6/09 at 03:04 PM Reply With Quote
Well mine have broken again!
sent them back to mnr today for repair. just hope i get them back in time, as i'm taking the car to Goodwood on friday.
i'll drive it without them if i have to
p*** off isn't the word
[Edited on 30/6/09 by Johneturbo]
graememk
posted on 30/6/09 at 03:09 PM Reply With Quote
are they hitting something when the wheels turn ?
smart51
posted on 30/6/09 at 03:15 PM Reply With Quote
Those are different to my wing stays but I had to replace both of mine. It is not an uncommon problem.
richardh
posted on 30/6/09 at 03:21 PM Reply With Quote
i've just changed to that style as my last style broke off too.
Don't tell me these vibrate and break also?
Silkaflexed the wings onto the stays and my first drive out since changed was ok.
great chassis, why is it that no other make has this trouble or am i being shortsighted?
Time for a change!
jacko
posted on 30/6/09 at 03:23 PM Reply With Quote
Just like Andy w 's SNAPPED
Johneturbo
posted on 30/6/09 at 03:25 PM Reply With Quote
graememk, na not hitting anything i think it's vibration that's doing it.
Smart51 they are a redesign to stop this happening! (they also broke on my last car)
GBaggott
posted on 30/6/09 at 03:28 PM Reply With Quote
I had a very similar problem on my MNR wing stays.
We welded on some small vertical sections, on you picture, roughly from wher the bolt is up to the top of the tube.
It was some careful filing to follow the contours of the tube etc.
However once welded on the problem has never re-occured
richardh
posted on 30/6/09 at 03:30 PM Reply With Quote
is it that weld that has gone?
is brazing them any better?
i put 4 rubber washers on (1 either side of each bolt) to help stop vibration
Time for a change!
GBaggott
posted on 30/6/09 at 03:33 PM Reply With Quote
Ill try and get a picture up later,
After the initial break mine were brazed.
posted on 30/6/09 at 03:38 PM Reply With Quote
My solution
LINKY
GeorgeM
posted on 30/6/09 at 03:40 PM Reply With Quote
It's not just MNR, lots do it.
Do a search
I think a 3rd stay to the top of the arch would
help though as there is quite a distance
between the two (almost 180 degs)
GeorgeM
PAUL FISHER
posted on 30/6/09 at 04:31 PM Reply With Quote
MK sports cars did mine like this on a raceleda upright,still going strong after 2 years,simple but strong.
James
posted on 30/6/09 at 04:39 PM Reply With Quote
That's a shame as I thought the MNR was one of the better designs. All the other manufacturers break too!
It's interesting that their's break at this point, whilst the types like the MK above break where the 3mm plate is welded.
What do Caterham do?
James
[Edited on 30/6/09 by James]
Fozzie
posted on 30/6/09 at 04:59 PM Reply With Quote
After one of mine broke on the way to Newlands a few years back.....
I did a redesign.......and with DLT's mega help, no welding..... mine have not broken since.......
Fozzie
Fozzie
Wheels244
posted on 30/6/09 at 08:36 PM Reply With Quote
That doesn't bode well -I've got the same design on mine
RichardK
posted on 30/6/09 at 08:43 PM Reply With Quote
This how I did mine,1500 miles and still rock solid.
Rich
Gallery updated 11/01/2011
PAUL FISHER
posted on 30/6/09 at 08:48 PM Reply With Quote
James
Here's a picture of the Caterham wing stay James,looks similar to the MNR one. Rescued attachment caterham wing stay.jpg
PAUL FISHER
posted on 30/6/09 at 08:56 PM Reply With Quote
Going back to the original picture though,the break is so straight and clean across 2/3 of it,I would put it down to lack of weld penetration,so he may just have been having a bad day welding that one up,so it may be a one off. Rescued attachment wingstay1.jpg
Johneturbo
posted on 30/6/09 at 09:00 PM Reply With Quote
Paul, the other fixing on the bolt you can't see had sheered off completly.
here's a pic of other side you can see where it has split
edited to say, 3 of the 4 fixings have split where the bolt is attached.
maybe thicker material is needed.
[Edited on 30/6/09 by Johneturbo] Rescued attachment wingstay2.jpg
PAUL FISHER
posted on 30/6/09 at 09:08 PM Reply With Quote
Oh dear,doe's not look like a one off then,that looks a real weak point,still think his welding penetration was rubbish though
RichardK
posted on 30/6/09 at 09:13 PM Reply With Quote
I tend to agree that the welding isn't good enough on that and the other hasn't got enough meat around the bolt area.
Rich
RichardK
posted on 30/6/09 at 09:18 PM Reply With Quote
Maybe this would be a better wayImage deleted by owner
Johneturbo
i guess we all have bad penetration days
must say these look good
http://www.locostbuilders.co.uk/viewthread.php?action=attachment&tid=116598&pid=975053
if only i can get them to mate up with my arches
paulf
posted on 30/6/09 at 09:20 PM Reply With Quote
It looks to me as if the tube is to rigid and the brackets to thin with a sharp angle at the end of the welds as a stress raiser.
I made mine from some tube about 15mm dia and used 3mm x 25 strip for the wing attachment with the joint between the strip and tube doubled up with a tapered section .They do flex but along the whole length rather than just at the joints between tube and plate.
The car has now been on the road for 5 years with no problems with them so far, although I may be tempting fate by saying so.
Paul.
Weld there is the flex point and being hard will fracture with the vibration. Nowt to do with penetration.
Mine are totally different to them being for Sierra uprights. IMO the mounting points were just too flimsy. Both of mine broke.
Some thicker plate and filleting have seen them OK for 2000 miles now.
<<  1    2  >>
