<<  1    2  >>
Author: Subject: Life expectancy of a 2.0 ford turbo diesel engine.
posted on 3/12/11 at 02:23 PM Reply With Quote
Originally posted by MikeRJ
Originally posted by snapper
Cheapest dual mass replacement round here is £750
DMF from Euro Car Parts is ~£236.
+ bolts + clutch + slave + optional starter which will add between £240 and £400
Then labour not a trivial job on this diesel especially with the heavy 6 speed box.
owelly
posted on 3/12/11 at 05:11 PM Reply With Quote
If the DMF has failed, chances are it will need the starter motor. The starter often fails before the DMF so check to see if its had either! The crap from the failing DMF ruins the starter.
http://www.ppcmag.co.uk
MikeR
posted on 3/12/11 at 05:19 PM Reply With Quote
ECP tend to do three levels of product - very cheap, cheap and oem equiv. Personally I wouldn't touch the very cheap and cheap if its for your own car. OEM equiv should be decent, last and be at a realistic price.
posted on 3/12/11 at 05:28 PM Reply With Quote
OEM would have been LUK ---- I have had seen a few too many LUK clutches with the centre part of the driven plate fractured.
I only buy LUK, Delphi or Valeo parts if nothing else is available.
eddbaz
posted on 3/12/11 at 05:43 PM Reply With Quote
Clutch went on mine at 120K then injectors at 170k so got rid.
<<  1    2  >>
