Author: Subject: 954 Airbox
liamb
posted on 28/8/08 at 09:44 AM Reply With Quote
954 Airbox
Hello.
It's been a few weeks since I had to buy anything for the car. I thought I had actually finished but I remembered yesterday that I still dont have any type of air filter solution.
I have had a look around and Demon Tweeks do a Pipercross airbox that mightr work but the problem is that I have no clue what I need.
Any help or advice would be great. The thing in question is:
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?c ls=MSPORT&pcode=P/CC6000
But it still need to fit to a baseplate and I don't know what I need for this?
Thanks in advance.
Liam
PS SVA finaly rebooked for the 9th of sept so need to get my skates on.
Paul TigerB6
posted on 28/8/08 at 10:03 AM Reply With Quote
The airbox uses the standard Pipercross PX600 aluminium baseplate as per the sponge filters - its on the list in that link as "replacement blank baseplate"
linky
ewan
posted on 28/8/08 at 10:11 AM Reply With Quote
If you look in my photos (side View) you will see what I did and cutting the back plate is easy.
bigfoot4616
posted on 28/8/08 at 10:20 AM Reply With Quote
i had very bad results with that airbox, the filter in the end of it is very small and restrictive.
for now i have removed the filter and fitted a canister filter into the inlet ducting which made a big improvement to fueling on the rolling road.
its still not an ideal setup though and i wouldn't recommend buying the airbox.
its cheaper elsewhere if you really want to buy it, have a search on here for "airbox"
liamb
posted on 28/8/08 at 10:45 AM Reply With Quote
Cheers for the feedback.
I am not too bothered whether I use an airbox or just a simple filter (although I am a little concerned about cutting noise).
The main thing is whether I get a standard PX600 baseplate and then modify it for a Honda Fireblade 954 engine or whether there is something more specific I should be using?
Liam
bigfoot4616
posted on 28/8/08 at 11:04 AM Reply With Quote
only reason i used a box is to get under 98db for places like croft. if i wasn't tracking it i would of stayed with the open filter.
you get a blank baseplate and cut out the holes to suit
liamb
posted on 28/8/08 at 12:26 PM Reply With Quote
Thanks for the advice.
I have similar concerns as I intend to use the car for trackdays but maybe I will start with a standard filter and see how things go.
Liam
charlierevell
posted on 28/8/08 at 03:19 PM Reply With Quote
Be careful what you chose! Mines read 104db at Oulton... and thats with the standard airbox!
Tango orange is an 'IN' colour!!
