<<  1    2  >>
Author: Subject: 4AGE GSXR Throttle Body Conversion
Lebowski
posted on 22/3/12 at 02:21 AM Reply With Quote
Looks like a nice job
Glade
posted on 29/3/12 at 03:24 PM Reply With Quote
Started fitting pipes last weekend. I have realised that with the new spacing the existing spacers in the fuel rail ONLY JUST fit, and it's a bit dodgy.
So I have knocked up a design for replacements, extended to fit snugly.
Also created a connector block and some shorter sections to join to the high pressure fuel line. I've sent it out to a local machine shop but I think that it'll cost a lot to get made...
ETA: Getting a machine shop local to me to do them... £75 - doing them tonight or tomorrow - should be able to pick up Sunday!
[Edited on 30/3/12 by Glade]
Glade
posted on 30/3/12 at 05:57 PM Reply With Quote
Within 24 hours these have been produced!
tasmod
posted on 3/4/12 at 01:30 PM Reply With Quote
Curious as to why you went to the trouble of making up the fuel rail and used the smaller GSXR injectors when the 4age has a very good setup with its own seperate fuel rail with correct injectors.
[Edited on 3-4-12 by tasmod]
Rob
Glade
posted on 3/4/12 at 01:41 PM Reply With Quote
I didn't have any original 4AGE parts.
The car had dellorto carbs, and a custom manifold when I got it.
I didn't consider sourcing the original manifold & injectors!! Isn't it a big curly thing??
tasmod
posted on 3/4/12 at 01:45 PM Reply With Quote
No, the injector rail is separate and bolts with spacers to the holes in the head top (side) if you get what i mean.
Rob
tasmod
posted on 3/4/12 at 01:57 PM Reply With Quote
You have U2U
Rob
Andybarbet
posted on 3/4/12 at 08:42 PM Reply With Quote
This is a great thread, im doing a similar thing on a zetec engine, same throttle bodies & modular fuel rail but I picked up an ali plate with 4 pipes on it type of inlet manifold.
Your fuel rail extensions are looking good :-)
Im planning on turning mine from some scrap brass rod ive found at work, did you keep the hole through the spacers the same diameter as the original ali ones ? or is it preferable to have a larger bore for the fuel to flow through them ?
If it works ok, im going to mill a flat on the outer 2 so that i can drill then tap into it, this way i should be able to screw in a brass hose connector for flow & return. I will post a picture when ive tried it.
Glade
posted on 3/4/12 at 08:55 PM Reply With Quote
I made them the same bore as the originals.
The connector block also has approximately the same gap within it where the pipes meet.
Andybarbet
posted on 3/4/12 at 09:01 PM Reply With Quote
I shall follow your lead then, atleast having the same bore as the original, it leaves me more 'meat' to mill a flat on & drill/tap into it.
HowardB
posted on 3/4/12 at 09:12 PM Reply With Quote
I made new fuel rail elements exactly the same, but now I don't need the throttle bodies or the st170 inlet manifold,.. all part of the joys of the evolving kit
Howard
AntonUK
posted on 3/4/12 at 09:34 PM Reply With Quote
Could I ask where you got your swirl pot and HP pump?
Build Photos Here
Glade
posted on 4/4/12 at 07:17 AM Reply With Quote
Ebay... £50 each.
There are some swirl pots there for £30 which look reasonable.
Glade
posted on 10/4/12 at 09:17 PM Reply With Quote
It started first time!
Tonight I mounted the swirl pot, pressure regulator & plumbed it all in.
Did a little wiring, created a clear path (to roll a burning inferno away from the house into my neighbour's garden), and went for it.
Cranked for about 20 secs, and it fired and settled into a reasonable idle!
Wahoooooo! Can't wait to let it run for a bit tomorrow!
MakeEverything
posted on 10/4/12 at 11:42 PM Reply With Quote
Great Thread. A word of warning though;
I bought one of those Pressure regulators, and it was causing massive lean spikes in the early stages of tuning (static low revs). It took me ages to realise it, but for some reason, the diaphragm isnt consistent and seems to flex randomly. I had the injectors cleaned, checked the throttle, fuel hoses, pump, filters and everything but. Eventually, i looked at my shiny new regulator and took it to bits. The internal quality is alarming, when you think of the consequences of it not working properly.
I took it off in the end and went back to the little OE item which works fine. I'm yet to be convinced i need to spend another £80+ on a proper FPR, as the OE one works so well.
Kindest Regards,
Richard.
Glade
posted on 11/4/12 at 06:27 AM Reply With Quote
I did wonder about it being so cheap!
Can anyone reccomend a suitable replacement??
How about this...
http://www.merlinmotorsport.co.uk/p1850/FUEL-PRESSURE-REGULATOR-8MM-+-GAUGE-PORT/product_info.html
[Edited on 11/4/12 by Glade]
Oddified
posted on 11/4/12 at 08:25 AM Reply With Quote
I also bought one of those cheap regulators, but i took it in bit's before fitting to have a look inside....rubbish. It never went on the car and it's that bad i decided not to off load it on ebay either
Took the pipe fittings off and threw it in the bin...
Ian
Glade
posted on 1/7/12 at 09:48 AM Reply With Quote
Just thought I'd update this...
Bought a better fuel regulator, car is running now. Just needs a remap - which is on hold due to lots of other stuff going on.
Doesn't look like the car is going to see the road this summer
fsmlittler
posted on 23/7/12 at 09:27 PM Reply With Quote
What fixings did you use for the throttle bodies to the adapter plates? There is very little space on the TBs for the bolts or did you tap the plates and use studs?
Also Ive got hold of the Jenvey modular fuel rail but it's designed for 14mm 'O' rings and the GSXRs are only 10mm-Jenvey say you can just put bigger 'O' rings onto the injectors-has anyone else done this?
Glade
posted on 24/7/12 at 11:14 AM Reply With Quote
I tapped holes and used one cap head screw on each TB.
The TB casting has something in the way of the right hand hole, and without some rework you can't get a screw in.
The interference fit with the bracket, the sealant and the single screw make it very solid though.
<<  1    2  >>
