<<  1    2  >>
Author: Subject: Swirl Pot
the dave
posted on 12/8/07 at 12:16 AM Reply With Quote
Swirl Pot
A question out of curiosity.
If i wanted to put an injection in my car instead of carbs, could i keep my fuel tank and fuel pump, but simply have the pump supplying a swirl pot from which the high pressure fuel pump could then pressurise the fuel rail.
It would be cheaper and i wouldn't have to pump in more fuel lines the whole length of my car for the returning fuel line.
What problems might there be with doing this?
[Edited on 12/8/07 by the dave]
phoenix70
posted on 12/8/07 at 02:27 AM Reply With Quote
In theory is might work, but my gut feeling is you would still need a return line to the fuel tank. The problem as I see it, is you will have your LP pump filling the swirl pot, and the return from the fuel rail filling the swirl pot.
Catatomic
Contributor
Posts 49
Registered 7/6/07
Location Uttoxeter
Member Is Offline
Photo Archive Go!
Building: Tiger Cat E1: Pinto GSXR 600 Throttle bodies, Mega
posted on 12/8/07 at 09:27 AM Reply With Quote
This was the next question that I was going to ask. I have a swirl pot on it's way and wanted to avoid plumbing in an extra return line. I was going to use a breather valve on the top outlet of the swirl pot.
Simon
I used a swirl pot with a new fuel supply pipe to the injector rail but I have used the carb supply pipe as the return. Works fine for me
Catatomic
Contributor
Posts 49
Registered 7/6/07
Location Uttoxeter
Member Is Offline
Photo Archive Go!
posted on 12/8/07 at 09:39 AM Reply With Quote
Can you clarify your setup please Rusty. Have you got two lines running to the fuel tank? How have you connected the top outlet/breather on the swirl pot?
Sorry if I am hijacking the thread, Dave.
Simon
the dave
posted on 12/8/07 at 10:17 AM Reply With Quote
no worries, it's all good stuff.
Hopefully a (very) rough sketch of what i had in mind. Rescued attachment swirl.jpg
posted on 12/8/07 at 11:45 AM Reply With Quote
Thats more or less how I did mine. I put the swirl pot as high as I could get it so that H.P pump is gravity fed , Haven't had any problems with set up .
Catatomic
Contributor
Posts 49
Registered 7/6/07
Location Uttoxeter
Member Is Offline
Photo Archive Go!
posted on 12/8/07 at 11:52 AM Reply With Quote
Thanks Dave and Rusty,
This is how I was thinking it would work.
I have only one connection on the fuel rail.
[Edited on 12/8/07 by Catatomic] Rescued attachment fuellingSwirl.png
the dave
posted on 12/8/07 at 12:11 PM Reply With Quote
That is probably more accurate, i don't yet have any parts, just planning.
2 questions, what TB's do you have Cat, and what does MAP stand for?
mark-wiring
posted on 12/8/07 at 06:42 PM Reply With Quote
MAP
Manifold Absolute Presure
http://www.v10viento.co.uk
Have to recommend
http://www.extraefi.co.uk/
For all Megasquirt needs
matt_claydon
posted on 12/8/07 at 06:53 PM Reply With Quote
Won't the LP pump just pi55 fuel out the breather?
[Edited on 12/8/07 by matt_claydon]
the dave
posted on 12/8/07 at 10:49 PM Reply With Quote
possibly, but when i started this thread i wasn't sure that the swirl pot needed a breather...
are we saying that this setup is not ideal?
DaveFJ
posted on 13/8/07 at 08:52 AM Reply With Quote
surely the swirl pot will just keep filling up? eventually the fuel will come out of the breather? especially if, for instance, you were idling the engine in traffic... low fuel consumption means more returned to swirl pot so it begins to fill....
personally I wouldn't risk it! the idea of overflowing fuel into the engine bay is scary! I'm not sure I would want to vent fuel vapour into the engine bay either!
Dave
posted on 13/8/07 at 09:27 AM Reply With Quote
Find a fuel return pot from a Sierra and place it between your low pressure pump and swirl pot then run the regulator return on the end of your fuel rail to the swirl pot. The breather is just somewhere for the fuel to escape especially if there is no pressure cut off on the Low pressure pump. The MAP reads the depression in the manifold not fuel pressure doesn't it?
[Edited on 13/8/07 by Peteff] Rescued attachment fuel system.jpeg
ecsjwhi2
posted on 13/8/07 at 09:48 AM Reply With Quote
To the dave
The breather from the swirl pot must be a return to the fuel tank. Your low pressure pump is working full tilt and at idle will easily fill the swirl pot. I have exactly the set up you have drawn except for the open breather, mine is a tank return, and it works perfectly.
JohnW
[Edited on 13/8/07 by ecsjwhi2]
DaveFJ
posted on 13/8/07 at 10:48 AM Reply With Quote
neat single line solution there from peteff !
Dave
the dave
posted on 13/8/07 at 03:52 PM Reply With Quote
This is the swirl pot i was thinking of using.
If i connect it up as shown would it work. The reason for asking is it would be cheaper to get the swirl pot than a new tank with a swirl built in.
EDIT : I missed out the regulator
[Edited on 13/8/07 by the dave] Rescued attachment 5.jpg
stevebubs
posted on 13/8/07 at 06:16 PM Reply With Quote
That's exactly how mine is connected up and works perfectly...
Catatomic
Contributor
Posts 49
Registered 7/6/07
Location Uttoxeter
Member Is Offline
Photo Archive Go!
posted on 17/8/07 at 06:30 AM Reply With Quote
I am using GSXR 600 throttle bodies. The reason I was trying to avoid a return line was to avoid clutter in the tunnel. I was going to put a non return valve on the breather and let the back pressure stop the LP pump (Facet)
Simon.
the dave
posted on 17/8/07 at 12:16 PM Reply With Quote
That is the same reason as me, as my car is already built plumbing in another fuel line would be tricky.
I can't see why that wouldnt work, unless there was too much fuel and it pressurized the swirl pot...but maybe not.
Might have to give that a try...not sure where to get the valve from though.
posted on 17/8/07 at 12:38 PM Reply With Quote
Simon.
What would the breather do in that instance? The two reasons for the return to the tank are to ensure the swirl pot is purged of air by the low pressure pump, and to keep the fuel cooler by recirculating it back to the tank.
With a non-return valve on top of the swirl pot leading to atmosphere, neither of these functions will be performed.
DaveFJ
posted on 17/8/07 at 01:08 PM Reply With Quote
to shamelessly steal PeteFF's rather neat solution......
I can see no reason why this would not work perfectly well and allow for only one pipe running the length of the car.
The pressure regulator at the rear would allow excess fuel to be recircualted to the tank when the swirl pot was full therefore removing the need for an overflow.
Dave
posted on 18/8/07 at 01:23 PM Reply With Quote
It won't purge itself of air very well though, i.e. the low pressure pump isn't going to be able to pump fuel into the swirl pot whilst it's full of air as there will be nowhere for the air to go. Eventualy the injectors will purge the air out but could take a long time. Best to stick a manual bleed nipple in the top of the swirl pot if you have to go this route.
Need to add a high pressure pump at the swirl pot end on the diagram as well.
posted on 18/8/07 at 02:43 PM Reply With Quote
I thought of a bike type tank mounted pump built into the swirl pot to keep the space needed to a minimum, forgot to put it in the picture. Doh!
paulf
posted on 18/8/07 at 04:58 PM Reply With Quote
I looked at various ways of doing this when I first injected my car.I wanted to use the existing mechanical pump on the crossflow and feed the swirlpot with that but decided that I really needed to fit a return line to vent vapour to the tank and also didnt like the idea of a litre or so of extra fuel in the engine bay swirl pot in the event of an engine bay fire.The fuel would also get very hot in the swirl pot whilst driving in traffic as little would be used and the underbonnet temperature would be raised, this would probably effect the mixture control and also be likely to cause high pressure fuel pump problems.
I eventually fitted the pot in the back of the car and ran a nylon fuel return pipe secured with a few P clips.
Paul.
<<  1    2  >>
