Author: Subject: Mazda donor
tri
posted on 26/8/12 at 12:10 AM Reply With Quote
Mazda donor
Hi
I have decided I want to build a Vortx using the mx5 donor just got a quick question about which mx5 I can use I was sure I read per 95 only but have since read differently can someone please clear this up for me I know either 1.6 or 1.8 will work just the age range I'm confused with
Tri
RK
posted on 26/8/12 at 12:49 AM Reply With Quote
Apparently, there is one with a particular crank issue, but I forget which is which. There was a CKC article a couple of months ago on this, by John Dickens.
theconrodkid
posted on 26/8/12 at 05:46 AM Reply With Quote
it,s the really early ones that are affected,if the fan belt pulley has 4 slots it,s a short nose and need looking at,if it has 6 slots it,s ok
[Edited on 26/8/12 by theconrodkid]
who cares who wins
pass the pork pies
BigLee
posted on 26/8/12 at 06:54 AM Reply With Quote
Correct. 4 slot is short nose and generally seen as the weaker engine. Long nose had 8 slots around the crank pulley and is the stronger of the 2. Pre '94 makes the emissions easier as you don't need a cat. Mine flew through even with a turbo. Import engines seem to be regarded as a little better, but I've yet to find a reason why. You can tell the difference by the O2 sensor. Uk has 4 wires, import has a single wire.
Lee
tri
posted on 26/8/12 at 08:29 PM Reply With Quote
Thanks for replies did not know about the engine problems does it matter the year for the kit or will most be able to be fitted
Tri
first350
posted on 27/8/12 at 03:09 AM Reply With Quote
I'm running a Miata Vortx, from a '99 miata.
IMO go with the 1.8 ('94 and later)
-more power
-Better diff (Torsen, rather than the VLSD in the 1.6L), also stronger
-Stronger Transmission
-bigger brakes (not really needed for a locost)
the early 1.8L's ('94-'95) were OBDI (simplier emissions), compared to the '95+ which are OBDII.
check out the below link, it lists all the miata from '90-'97, it's helpful in figuring out which ones came with a LSD; I've found it's a good gauge, but I always call Mazda anyways to run the VIN and double check what options it came with...so many people mod them.
http://www.miata.net/faq/Miata90-97A3.pdf
hope that helps!
