Author: Subject: MT75 Modification help
Front Row Joe
posted on 2/12/09 at 01:04 PM Reply With Quote
I'm in the porcess of offering my engine and gearbox up to the car for the first time. I need a little more clearance in my transmission tunnel to get the gearbox back a little further. I'm using an MT75 and there are four square lumps (2 either side of the box) which look to be solid ally. Can I grind these off without causing structural problems?? Any advice would be appreciated I can't seemed to find any previous posts on the matter.
Joe
mangogrooveworkshop
posted on 2/12/09 at 01:40 PM Reply With Quote
Any pics?
Dont think it will cause a problem..
whilst on the subject of trimming bits off
See the seirra diff... it has a nose on the rear be very careful how much you grind off that some have been left with a 20 mm dia hole to fill
stevec
posted on 2/12/09 at 01:43 PM Reply With Quote
do you mean these things? If so I reckon you will be ok.
Bluemoon
posted on 2/12/09 at 03:02 PM Reply With Quote
Humm I'd want to know what they where for. You might find they are part of the selector mechanism.. On the other hand they might not be! I don't suppose the MT75 has an inspection plate like the type 9 you could then look inside..
dan
RAYLEE29
posted on 2/12/09 at 03:03 PM Reply With Quote
dont think the one in the pic will fit unless you move your seat very high lol
Ray
RAYLEE29
posted on 2/12/09 at 03:06 PM Reply With Quote
seriously though i think they are there for machining purposes but id look in the case before cutting them off
Ray
Front Row Joe
posted on 2/12/09 at 03:55 PM Reply With Quote
Cheers gents. The photo above (stevec)is what I'm on about. I'm happy to remove the two at the front. You can see they have no purpose by looking in the bell housing. I guess they were excess after the casting or to assist in storage. It's the one's at the back I'm worried about as I can't see behind them. I don't want to be left with a hole. Cheers for the advice re the diff. I was going to hack that off. Will have to careful now........
philtvr
posted on 2/12/09 at 03:56 PM Reply With Quote
Westfield instructions tells you to grind the lumps off to fit the mt75 into there chassis.
Marlon
posted on 2/12/09 at 04:56 PM Reply With Quote
I have chopped them off on mine with no problems, they are just there from the casting process.
john.
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
big_wasa
posted on 2/12/09 at 04:57 PM Reply With Quote
yes ive cut them of mine and more besides.
Ive also modified the reverse switch to get more clearance.
Front Row Joe
posted on 2/12/09 at 06:16 PM Reply With Quote
Thanks for your help. Angle grinder at the ready. With a fresh disc of course!
r1_pete
posted on 2/12/09 at 07:39 PM Reply With Quote
Yes I cut mine off too, just lumps of ally, maybe for holding purposes during factory assembly.
posted on 3/12/09 at 12:02 AM Reply With Quote
Not supposed to grind aluminium at all with a ferrous grinding disc!
Front Row Joe
posted on 3/12/09 at 05:28 PM Reply With Quote
All ground off and looking shiney. No problems at all. I didn't generate any fireballs with the grinder either.
Bluemoon
posted on 3/12/09 at 06:12 PM Reply With Quote
^^ it's not fire balls, more exploding disks...
