<<  1    2  >>
Author: Subject: roughly how much is it to rebuild a pinto
jpindy3
posted on 21/6/09 at 08:30 PM Reply With Quote
I don't think you have done major damage. The cam looks fine to me.
If you are worried about the mains and Big ends then you will have to pull the engine out, drop the sump off and check the bearings. If you do it soon then you can pop a new set of shells in and it should be as good as new. If you leave it with worn shells for a period of time you risk damaging the crank.
Even if you just leave it and you do end up damaging the crank then you are still only looking at a couple of hundred to put it right.
I would leave it and watch the oil pressure - it should be about 60 psi max and 20 psi or so on tickover. It will be higher on tickover when new so if it has just dropped to 20 or so now then you have accelerated the running in process a little.
ahh ok
it has a high presure oil pump,so my pressure is a bit higher than that,
when wormed and driving it is at 6bar 80 odd psi and at idle it drops to 4.5-5bar,
before this happend with the oil cock up,
it ran 6bar driving and just under 6 at idle,
it is a new engine,coverd 200miles
jpindy3
posted on 21/6/09 at 08:34 PM Reply With Quote
Originally posted by prawnabie
[quoteI would look at the slight mark on the lobe though.
Hence me saying it looks worn
it look worse than it is in that pic,it was like that when i got the engine,
its not a chip or a crack,
Ray
posted on 21/6/09 at 08:56 PM Reply With Quote
Jem engines will do you a 2.1 pinto and big valve head for around the £1500 pound mark
cheers Ray
jpindy3
posted on 21/6/09 at 09:13 PM Reply With Quote
cheers Ray
ok thanks but i already have a vulcan 21L big valve pinto,
mookaloid
posted on 21/6/09 at 10:00 PM Reply With Quote
ahh ok
Don't worry about it - you have got away with it.
posted on 22/6/09 at 09:31 AM Reply With Quote
that cam looks good for 50,000 miles or more.
jpindy3
posted on 22/6/09 at 09:54 AM Reply With Quote
ok thank lads,
right what im doing is rebuilding my 202 block now with eather cossie of forged pistons ready for my turbo,
so a
when i have done this at lest i have a bottom end to fall back on if the other blows
<<  1    2  >>
