novacaine
posted on 20/4/09 at 09:26 PM |
Which zetec cam?
Hi all,
After being confused by the burton power website I'm after some recomendations for a cam for a 2.0 silvertop
I'm happy to put up with a lumpy idle to get a good high performance cam
Do cam kits generally come with springs?
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but
your older, shorter of breath and one day closer to death
zetec
posted on 20/4/09 at 09:36 PM |
Cams dont normally come with springs. You need to decide if you want to change pistons and valve train. If you don't then Piper 285 is normally
the way to go...it should be fine using all standard parts if rev limit is kept below about 7300 and will give about 200 bhp, just check piston
clearance before firing up. Cam choice will be dependent on whether you want to port the head, if not going for anything too wild will be a waste.
Also you don't mention what fuel system you have.
austin man
posted on 20/4/09 at 09:37 PM |
doesnt your zetec have hydraulic lifters ??
novacaine
posted on 20/4/09 at 09:59 PM |
Will be running it on megasquirt and bike throttle bodies, 200-220 would be my target, maybe more depending on cost
I don't really want to get into changing pistons but I might get the head ported, again depending on cost
Thanks for the replies
Matt
catman
posted on 21/4/09 at 09:54 AM |
ive got some Fz2001's for sale with matching followers, these are good for 195bhp on a properly sorted engine,cost over £400 new, im after
£190
Ed
caged supersix
Carbon/GRP
210 bhp silvertop
190 lbft
