<<  1    2  >>
Author: Subject: how much can you modify a car before requiring SVA/IVA?
renrut
posted on 15/9/09 at 03:06 PM Reply With Quote
I think the main thing is keeping within the spirit of the rules. It seems you can bend them a little here and there but try to bend too many at once or one in a big way and I'm sure it'll only end badly.
Its all to do with safety at the end of the day. 1 drilled hole to fit through a pipe or cable is very unlikely to cause someone to die/be injured but a front frame holding the brakes and suspension and the large engine weight, if designed or built in a substandard way where the hole thing could detach at speed is likely to be viewed very dimly.
That said you can completely bin the monocoque of a car and provided you use all the parts from the donor, you would still gather enough points to save you from IVA...
Why are all the fun things in life expensive!
<<  1    2  >>
