<<  1    2  >>
Author: Subject: Where to start? New BMW garage heater!!
franky
posted on 29/1/10 at 05:26 PM Reply With Quote
I've now got the e36 m3 sat in my garage...
Now where the hell do I start on taking it to bits!?
I was thinking...
1 engine and box out
2 sell all the rest of the trim/bits that I can
3 out the garage, on bricks, remove suspension legs/brakes etc
4 Give the scrap man a call.
Does that sound about right?
tegwin
posted on 29/1/10 at 05:29 PM Reply With Quote
I was thinking...
2 Give Tegwin a ring so he can pick the engine up
3 sell all the rest of the trim/bits that I can
4 out the garage, on bricks, remove suspension legs/brakes etc
5 Give the scrap man a call.
EFA
[Edited on 29/1/10 by tegwin]
www.verticalhorizonsmedia.tv
twybrow
Sounds about right. I would also take all of the loom (it could be chopped down to fit your car), the steering column/switch gear/wheel and as many bulbs as you can be arsed to scavenge!
NigeEss
posted on 29/1/10 at 05:31 PM Reply With Quote
Depends on your time scale. If you can sell first taking bits off as you do it'll take up
a lot less space. Amazing how much room a car fills when in bits !
franky
posted on 29/1/10 at 05:32 PM Reply With Quote
cool. Parts I need are...
Engine
Diff
Engine loom
Clocks
Gearbox
Steering parts
wheels
I'm not allowed to strip it on the drive as my long haired boss thinks we'll look like 'travelers'
omega0684
what the feck car is that going into?
franky
posted on 29/1/10 at 05:35 PM Reply With Quote
In a very distant future a GKD Legend six.
Its so much more cost effective. ITB's as standard, its ECU has been mapped to perfection and it already makes just over 300bhp so more than enough poke.
coupled with the LSD etc its cheaper than building a duratec on TB's.
[Edited on 29/1/10 by franky]
dlatch
posted on 29/1/10 at 05:40 PM Reply With Quote
great choice of engine they really are a cracker and when 300bhp is not enough always SC options
Miks15
posted on 29/1/10 at 05:47 PM Reply With Quote
just a little help,the front slam panel can be removed so the engine can come out forwards.
If you disconnect the gear lever, you wont need to worry about tipping the engine up, just on a crane and either wheel the crane one way, or the car the other.
If you have any queries on how to take the car apart just give me a shout, i did my E36 couple years ago now (ok it was only a 1.6 and not an M3) but alot of the fiddly bits could be the same
Also, someone payed me £150 for the shell of mine, so dont just go to the scrappy. Someone might be looking for a shell (jus remember to grind off all ID numbers)
big_wasa
posted on 29/1/10 at 05:48 PM Reply With Quote
oh I so like the look of that
franky
posted on 29/1/10 at 05:53 PM Reply With Quote
Thats exactly what i'm hoping, i've taken the front slam panel off.... just got to get everything else connected off.
The more tips to getting it out the better. what else apart from all the engine mounts etc need to come off to do it? I was thinking of resting it on wood and pushing the car off it but the crane is a good idea too. Just tight on space though as they're bloody big motors!
this pic is where i'm at now...
Miks15
posted on 29/1/10 at 06:00 PM Reply With Quote
eerrrmmm...
prop, exhaust loom, TB's coolant lines, obvs engine mounts, gearbox mounts, PAS lines, AC lines, Heater lines.
if you get the main things off, slowly move it, if you feel a snag then you can inspect to see whats stopping it.
Under the engine (if its anything like mine was, theyll be a cross member that bolts to the chassis. The engine then bolts to this cross member. if i remeber correctly, the steering rack also connects to this. I think this cross member might be in the way of the sump coming directly past it, so it might be wise to drop the cross member and steering rack as opposed to just undoing the engine mounts
MikeR
posted on 29/1/10 at 06:09 PM Reply With Quote
keep all the nuts and bolts as you strip it - if you don't use them on the rebuild / new build you'll find a use for them at some point.
franky
posted on 29/1/10 at 06:24 PM Reply With Quote
eerrrmmm...
Sounds like a plan. Should be able to do it in half a day all going well.
Been looking at ebay too and all the parts I don't need seem to go for decent money so fingers crossed i'll get most of the cost back.
jollygreengiant
posted on 29/1/10 at 06:31 PM Reply With Quote
I know it might be a pain in the ar$e doing it but DON'T cut any wiring, just take out the ENTIRE loom and all fuse boxes, relays and ECU's. then you won't want any electrical cables and you can always re-use the switches as necessary.
James
posted on 29/1/10 at 06:35 PM Reply With Quote
Once it's out, could you do some quick measurements of engine/gearbox please?
My car is approaching Viento size... reckon one of these babies would fit quite nicely.
Are they auto gearbox? Pretty sure my mate's was.
How much of a challenge is it to use the stock ECU (and therefore Loom presumably) without needing locks, ignition key, immobiliser etc. etc.?
How come you went for this one, not the EVO at 320bhp?
Looks great!
James
[Edited on 29/1/10 by James]
James
posted on 29/1/10 at 06:41 PM Reply With Quote
I think I attempted that with my Sierra donor.
I don't think it was possible!!! I'd have had to cut the car apart around the loom! Too many connectors put on after the loom has been fed through bulkheads etc.
James
Simon
posted on 29/1/10 at 06:47 PM Reply With Quote
Shouldn't worry about that, if the council thinks they've got pikies, they'll probably give you a grant
Simon
franky
posted on 29/1/10 at 06:48 PM Reply With Quote
Looks great!
James
No worries will do, just let me know what you need. If you get a 3.0 they're very easy to get running.
5 sp ZF bomb proof manual.
I went for this over the 3.2 as....
1) Single vanos unit that do not have the issues the 3.2 have.
2) Gearbox's are stronger, the race cars fit this box to a 3.2 unit.
3) the EVO hardly ever makes its claimed 321bhp... when this was on a dyno at a dyno day it make more poke than 7 evo's, only one evo made more at 315bhp with a 8.2k rev limit.
4) Price
5) Price again!
gottabedone
posted on 29/1/10 at 07:07 PM Reply With Quote
when you take all of your loom out, if you also take the all of the lights and other electrickery bits then you can reconnect when off the car. It makes chasing wires and finding faults a lot easier. You can later remove all of the bits that you don't need and sell on any that you can.
I would also remove anything that connects to anything with the steering, suspension, fuel, exhaust etc. as it will make life easier if you have to set up the mounting points on your new chassis and answering the @which way round does this go" questions
This will be a serious toy when finished
maartenromijn
posted on 29/1/10 at 07:13 PM Reply With Quote
James
I did it with a 1993 Mondeo! The engine out costs 1 day, and the wiring loom 3 days! I have put a piece of tape at every connector and written what the connector is for.
BLOG: http://thunderroad-super7.blogspot.com/
franky
posted on 29/1/10 at 07:16 PM Reply With Quote
Thats what i've been doing with this, the good news is that the engine loom connects to the main loom with block connectors.
Richard Quinn
posted on 29/1/10 at 07:49 PM Reply With Quote
Don't know where the earth strap is on that motor but that's the one that normally catches me out! The number of cars I've ended up lifting in the air with the crane because the bloody earth strap is still attached!!
dave-69isit
posted on 29/1/10 at 09:07 PM Reply With Quote
on my last on earth straps on starter motor
pdm
posted on 29/1/10 at 09:20 PM Reply With Quote
Will you need any mods to the standard Legend 6 chassis to fit engine/gearbox ?
Are you using the M3 prop, diff and half shafts or are you mating to a standard diff/halftshafts ?
What are you doing about front hubs/calipers - going with the M3 ones or using standard ones ? Same for rear flanges - are you going for standard ones ?
It's going to be one awesome motor when it's done !!
thanks
Paul
<<  1    2  >>
