<<  1    2  >>
Author: Subject: Where to start? New BMW garage heater!!
franky
posted on 29/1/10 at 09:30 PM Reply With Quote
the chassis is designed to fit the m3 engine so it'll go straight in.
I'm going to use bmw 328 brakes as they're a little smaller so will heat up better. These are too big at 310mm
So front discs will be 286mm rear will be 280mm.
I'll need a new prop but they're not too expensive.
I'll be using the m3 LSD diff with bmw 328 drive shafts.
[Edited on 29/1/10 by franky]
col
posted on 6/2/10 at 07:16 PM Reply With Quote
As with some other cars dont you need to keep the ignition etc as these bmers have unusual imobilisers?.........its only what ive heard
Bluemoon
posted on 6/2/10 at 09:10 PM Reply With Quote
Originally posted by James
Originally posted by jollygreengiant
I know it might be a pain in the ar$e doing it but DON'T cut any wiring, just take out the ENTIRE loom and all fuse boxes, relays and ECU's.
I think I attempted that with my Sierra donor.
I don't think it was possible!!! I'd have had to cut the car apart around the loom! Too many connectors put on after the loom has been fed through bulkheads etc.
James
Got mine out complete from the sierra, all of it! I like a challenge (but this would have been simpler than the BMW)! It does help to have it as you know it all will work, and things like the haynes manual tell porky's about the wiring; some times it's simpler to trace if you have the whole loom (but label everything, be careful to keep the labels in good condition i.e. don't fall off in the X number of years before you need it!)..
I guess with GTD you will use a new loom anyhow?
Dan
franky
posted on 8/2/10 at 08:42 AM Reply With Quote
My car's a pre EWS which is the extra security part of it so its not such an issue and even for those with its a good way to meet IVA requirements.
I'll be making up a new loom for lights etc but using the engine loom as it has a nice big plug to the main loom and keeps everything looking tidy.
<<  1    2  >>
