Author: Subject: Zetec engine choice and fuel/ign options.
loggyboy
posted on 10/4/10 at 09:06 PM Reply With Quote
Ive been narrowing down mu engine choice and it seems that a zetec is coming out top of the list. (Good power output, Easy bolt to type 9, Easy and good value 'new buy' for new registration.)
However what ive not looked in to is fueling and ignition. Ive been recommened TBs and Omex, but this seems expensive, what are the other options?
MakeEverything
posted on 10/4/10 at 09:08 PM Reply With Quote
2.9 cosworth V6 is also readily available, takes the type 9 from the 2.8 capri with the capri bellhousing.
Go Megasquirt. Buy one already assembled for around £300. Its really diverse.
Kindest Regards,
Richard.
stuart_g
posted on 10/4/10 at 09:13 PM Reply With Quote
Omex and bike TB's shouldn't be too expensive.
tomgregory2000
posted on 10/4/10 at 09:20 PM Reply With Quote
new reg = new parts!
new parts = expensive
austin man
posted on 10/4/10 at 09:21 PM Reply With Quote
megasquirt will allways be the money saver, omex can come with map pre installed, Emerald are a good ecu and good support.
zetec
posted on 10/4/10 at 09:24 PM Reply With Quote
I think it's Retro Ford who do a TB and ECU setup for about £1700. Not cheap but easy fit and startup.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
Paul TigerB6
posted on 11/4/10 at 12:32 AM Reply With Quote
simple answer - pre Aug 95 then bike carbs / megajolt.
Post Aug 95 then bike tb's / megasquirt
[Edited on 11/4/10 by Paul TigerB6]
big_wasa
posted on 11/4/10 at 08:27 AM Reply With Quote
There are tons of options.
The first question has to be whats your budget ?
Do you need new parts for a new reg ?
And what ever way you look at it Power costs money £££££££
Danozeman
posted on 11/4/10 at 08:56 AM Reply With Quote
New engines dont come with an engine number i believe so may be difficult to IVA??
But yes id go with Paul tiger's idea if your on a budget.
Dan
luke
posted on 11/4/10 at 09:32 AM Reply With Quote
Only need engine number to prove the age of the engine to get the emissions tested to the relevant specs for the age of the engine. If going for a newbuild plate it will be tested to the latest emissions standards so age of engine doesn't matter.
fatbaldbloke
posted on 11/4/10 at 05:11 PM Reply With Quote
Relevant page on my website
I've written up what I did with bike throttle bodies and megasquirt on the Zetec in my Westfield on my website. You might find some useful info there?
