Author: Subject: Reversing lights and MOT's
rf900rush
posted on 22/6/10 at 08:23 PM Reply With Quote
Just changed my broken reversing BEC box to a new MNR one.
Just found no reversing light switch.
So my question is.....
Can I use a seperate dash mounted switch for the rear light , and be MOT complient ?
Ideal woluld be a bracket and a switch, but time is short at the moment.
tomgregory2000
posted on 22/6/10 at 08:29 PM Reply With Quote
A reverse light is NOT needed for MOT
Not tested
vyperstrype
posted on 22/6/10 at 08:30 PM Reply With Quote
Reverse Light
To be honest, i don't think Reversing Lights are a compulsory item for MOT. I have no Reverse Lights fitted to my Indy, and it passes an MOT every year.
Cheers Eric.
Where there's a will, there's a death!!
mad4x4
posted on 22/6/10 at 08:33 PM Reply With Quote
as above not required for MOT
Scot's do it better in Kilts.
posted on 22/6/10 at 08:36 PM Reply With Quote
As above, don't worry
DRC INDY 7
posted on 22/6/10 at 08:41 PM Reply With Quote
Reverse light is not tested and does not have to be fitted
as you are not allowed to show white light to the rear hench when your rear light unit is cracked and it shows white light its a fail
Puddle Dodgers Club
Cousin Cleotis
posted on 22/6/10 at 09:56 PM Reply With Quote
Showing white light to the rear doesnt come into the MOT test, a cracked lense would fail because the light would be the wrong colour, eg not amber if it was an indicator, pedantic i know but thats the way it is.
This is the exact same manual that is accessed from an MOT computer, http://www.motinfo.gov.uk/htdocs/index.htm
Paul
blakep82
posted on 22/6/10 at 10:12 PM Reply With Quote
doesn't even have to work if fitted
________________________
rf900rush
posted on 22/6/10 at 10:42 PM Reply With Quote
That make's things easy.
DRC INDY 7
posted on 22/6/10 at 11:11 PM Reply With Quote
Paul
ok so if the bulb is not coloured red or amber for the rear then it would be white light shown to the rear (wrong colour) therfore a fail dont teach me how to do my job
Puddle Dodgers Club
SeaBass
posted on 23/6/10 at 07:22 AM Reply With Quote
Eh? That means every car with a reverse light would fail...
They are a recognised option and if fitted to a vehicle after 86 should be e-marked and ideally work automatically from the box.
If you fit a switch you'll also need to install a tell tale on the dash to remind you to switch it off.
See here:
http://www.opsi.gov.uk/si/si1989/Uksi_19891796_en_19.htm#nsch14requirementrelatingoptionalreversinglamp
[Edited on 23/6/10 by SeaBass]
Cousin Cleotis
posted on 23/6/10 at 08:48 AM Reply With Quote
Paul
The bulb could be any other colour than it should be and it would fail, not just white. What about all the cars on the road with a number plate light on the top of the rear bumper, clearly showing white light to the rear? Do you fail all of these?
Paul
MOT Tester
[Edited on 23/6/10 by Cousin Cleotis]
DRC INDY 7
posted on 23/6/10 at 10:48 AM Reply With Quote
what has the number plate light got to do with the reverse light question number plate lights do not face the rear they shine onto the number plate the reflection from that is not a fail getting back to original question reverse lights are not tested so i say again do not teach me my job with your stupid coments
Puddle Dodgers Club
Cousin Cleotis
posted on 23/6/10 at 11:50 AM Reply With Quote
Some of the comments in this thread are misleading, showing white light to the rear of a car does not come into the MOT test.
On some number plate lights you can quite clearly see the lens of the light, not just the reflection.
There was no personal attack from me. There are is no need for comments like this "i say again do not teach me my job with your stupid coments"
Paul
SeaBass
posted on 23/6/10 at 12:03 PM Reply With Quote
Woo hoo it's an MoT Tester battle...
To lighten the tone guys -
1) I think his question has been answered
2) I've had to "steer" my MoT tester towards the correct regulations a few times but we're still good pals and I didn't need to "teach him his job"!
DRC INDY 7
posted on 23/6/10 at 12:42 PM Reply With Quote
yes you can see white light with some lights but the light is not facing the rear like the tail lights thats why its not a fail the reason i say white light is because the correct colour bulb for number plate lights and reverse light is white im not talking about other colour bulbs because they are illegal to use anyway simples
Puddle Dodgers Club
DRC INDY 7
posted on 30/6/10 at 10:14 PM Reply With Quote
Paul
I must refer you to number plate lights RFR id number 7037 Shows direct white light to the rear thens its a fail
Information Method of Inspection Reason for Rejection This inspection applies to all vehicles fitted with front and rear position lamps. Registration Plate Lamps Registration plate lamps are the lamps that illuminate the rear registration plate. Some vehicles may have these lamps fitted behind the number plate. Multiple Registration Plate Lamps Where more than one rear registration plate lamp, or bulb, is fitted as original equipment, any one inoperative lamp or bulb is a Reason for Rejection. Tricycle and quadricycle requirements are detailed at Section 9.1. C. Registration Plate Lamps 1. Turn on the position lamps and check that registration plate lamp(s): a. are fitted b. are secure c. are working d. are correctly positioned e. does not show white light to the rear. 1. A rear registration plate lamp: a. not fitted b. insecure c. with any bulb not working d. not illuminating the rear registration plate e. shows white light directly to the rear 1.1 Front and Rear Position lamps and Registration Plate Lamps
[Edited on 6/30/2010 by DRC INDY 7]
Puddle Dodgers Club
