sorens2
| posted on 23/8/10 at 02:34 PM |
Another DIY upgrade - Cold air feed - PIX
Now that I closed the gap around til radiator the temp i the enginebay is quite high.
My copilot had his leg burned just from the air flowing into the passengerside from the enginebay.
Something had to be done to keep BHP up.
Bought this airbox from Pipercross.
As it was from MNR:
Had to make a new backplate:
Filter is inside the box:
Air is sucked in in front of the radiator:
I don´t think there will be much "Ram effect"
I fits....but close.
Strait through
Soren S2
[Edited on 23/8/10 by sorens2]
andrew-theasby
| posted on 23/8/10 at 03:09 PM |
How tall does it sit off the flange?
loggyboy
Should help nicely, some 'ram air' induction going on their too.
Why do I see an image of the 2 Dutch Police officers from Harry Enfield/Paul Whitehouse
loggyboy
| posted on 23/8/10 at 03:11 PM |
sorens2
| posted on 23/8/10 at 03:33 PM |
What do you mean "Off the flange"
From where to where ?
Soren S2
dan__wright
| posted on 23/8/10 at 03:42 PM |
i think he means the backplate.
have you considered adding vents at the back of the engine bay? should give the hot air somewhere to escape
FREE THE ROADSTER ONE…!!
sorens2
| posted on 23/8/10 at 04:13 PM |
So far its going under the car.
Soren S2
Lightning
| posted on 23/8/10 at 04:20 PM |
Have you tried it yet. When I did similar on mine the difference was considerble.
sorens2
| posted on 23/8/10 at 04:25 PM |
Its raining like in Pakistan at the moment.
But Ill try it at the Nordschleife i 10 days
Soren S2
andrew-theasby
| posted on 23/8/10 at 05:59 PM |
Ye sorry i meant how tall off the backplate? Does it have a filter anywhere? Looks like just what i was considering making soon
sorens2
| posted on 23/8/10 at 06:18 PM |
In pic 4 from the top you can just see the filter inside.
It is a 100 mm filter that sits in the intake of the box.
Not like the oldstyle panel filter.
They reccomend 100 mm if you go above 200 bhp.
Can´t wait to try it.
Soren S2
bi22le
| posted on 23/8/10 at 08:44 PM |
Looks tidy.
You will have to post back and tell us if it makes a difference.
Please read my ring story:
Dusty
| posted on 23/8/10 at 09:22 PM |
You still need to do more to get hot air out from under the bonnet IMO.
sorens2
| posted on 7/9/10 at 05:38 AM |
Tried it at the Ring this weekend.
Normally I don´t hit the rev limiter as the engine goes a bit dull over 11000 rpm so it gomes natural when to change up.
BUT NOW !!!
Hit the limiter at least 15 times this weekend because it just keeps on racing up the scale.
Much more high rpm power and it feels much better.
Huge difference.
Noise is the same.
Soren S2
Major Stare
| posted on 6/10/10 at 09:48 PM |
Do you have a PowerCommander to get the engine re-mapped?
I
Jon "FISH"
sorens2
| posted on 7/10/10 at 04:39 AM |
Yes.
Soren S2
elf83
| posted on 11/4/11 at 09:56 PM |
Where did you get this airbox? i cant find it anywhere? do they do it for a k2 gsxr 1000?
mistergrumpy
| posted on 11/4/11 at 10:12 PM |
See here for example. It's a Pipercross 600
series.
austin man
| posted on 11/4/11 at 10:39 PM |
vent your side panels see photo in my archive this will reduce water temperature by around 10 degrees
wilkingj
| posted on 12/4/11 at 07:26 AM |
Have you heat wrapped the parts of the exhaust piep that are still inside the engine compartment. That will reduce your under bonnet temperature quite
a lot, for not a lot of work / money.
Best Regards
Geoff
http://www.v8viento.co.uk
sorens2
| posted on 12/4/11 at 03:09 PM |
This mod sorted all my problems.
The engine runs like never before now.
Soren S2
