<<  1    2  >>
New Topic New Reply
Author: Subject: Stiffening chassis?
sebastiaan
posted on 15/1/11 at 07:16 PM Reply With Quote
Stiffening chassis?
Hi guys,
I've taken the engine (pinto) out of my MK this afternoon in anticipation of the winter upgrades. Now that the engine is out, I'd like to take the opportunity to increase the chassis stiffness a bit. The Indy chassis doesn't have the "R" tubes at the top of the engine bay nor the alternative "Y-braces" and this of course does not do the torsional stiffness any favours. Due to the design of my inlet & exhaust manifolds, those braces would also not fit my car. Has anyone done something to increase the chassis stiffness of the Indy? I know the "aussie mods" and have also seen Cymtrik's work on this but maybe there are other ideas out there...
Sebastiaan
interestedparty
posted on 15/1/11 at 07:51 PM Reply With Quote
I suggest you put up a photo of the car without the engine in it, it would make it easier for people to make suggestions as to where stiffening could be added.
jacko
posted on 15/1/11 at 09:54 PM Reply With Quote
What makes you think it needs stiffening ? MK have sold lot's of indy's and i cant think of any i have seen with the R tube or Y bars Track or Road
Jacko
sebastiaan
posted on 16/1/11 at 10:38 AM Reply With Quote
Jacko
That's exactly the point. The R-braces add a lot of stiffness to the chassis and have been omitted from the MK chassis in order to be able to fit a lot if different engines easily. if you look at the top rails making up the engine bay, the whole thing is in essence not triangulated at all...
I'll see if I can dig up a picture.
*Edit* found something in the photo archive.
Early days
Early days
[Edited on 16/1/11 by sebastiaan]
sebastiaan
posted on 16/1/11 at 11:29 AM Reply With Quote
This'd be the simplest way of adding the R-tube, but my exhaust interferec with it as it drops slightly below the level of the top chassis rail between the engine and the side rail (Pinto with MK manifold)
Simple R-race added
Simple R-race added
Doubling up on the R-braces gives this, which also does not work at the inlet side because of the inlet manifold....
2x R-brace added
2x R-brace added
And this is me going wild...
Descriptiolots of bracing
jacko
posted on 17/1/11 at 06:29 PM Reply With Quote
Back to my first post
what makes you think you need them ? if no other Indy's have them
Have you read /seen any indys that have fallen apart etc ?
Maybe because the indy has steel bulk heads that add's strength ?
Ps i don't have anything to do with MK
Jacko
[Edited on 17/1/11 by jacko]
indykid
posted on 17/1/11 at 07:05 PM Reply With Quote
Jacko
i find i get significant scuttle shake from the front end over rough surfaces as the completely undamped spring of the front end wobbles about.
torsional stiffness isn't essential (and there have been many cars with floppy bodies produced over the years), but it certainly helps the suspension do its job. adding the engine braces and probably a tube across the top of the footwells would add a lot of stiffness.
MKs aren't built as a serious racer and they suit their purpose for the majority. that doesn't mean it's wrong to want to improve them though, nor that they can't be improved because they don't fall apart
jacko
posted on 17/1/11 at 07:42 PM Reply With Quote
Jacko
Fair point
i will get my coat
Graham
RichardK
posted on 17/1/11 at 08:11 PM Reply With Quote
I stuck an extra one in that doubles as a front engine mount too.
Although my scuttle doesn't tend to shake, just the rest of the car!
Rich
Gallery updated 11/01/2011
posted on 17/1/11 at 08:19 PM Reply With Quote
Fit a bike engine as part of your upgrade and you get the additional bracing to aid installation.........
Phil
jacko
posted on 17/1/11 at 08:45 PM Reply With Quote
Yes but a bike engine doesn't have the TORQUE of a proper engine
sebastiaan
posted on 17/1/11 at 09:50 PM Reply With Quote
Phil
Well, I almost asked for that one, didn't I?
posted on 17/1/11 at 09:53 PM Reply With Quote
What you fail to remember, is that bike engines have a torque multiplier in the form of a primary reduction gear
Phil
posted on 17/1/11 at 09:56 PM Reply With Quote
Phil
LOL
mcerd1
posted on 17/1/11 at 10:11 PM Reply With Quote
if you were going to do something like that (which is probably way ott) then what about something more like this on the sides:
that way you save those two vertical bits you had comeing up from the engine mounts, but keep the extra stiffening at the mounts
(I'm no chassis design expert, but its what I'd do on any of the lattice structures I design at work)
if you want to see a chassis with lots of bracing have a look at a dax:
[Edited on 17/1/2011 by mcerd1]
James
posted on 28/3/11 at 10:47 PM Reply With Quote
Sebastiaan,
Missed this post before.
If you're still looking for a solution, have a look at the 'spiderweb brace' that Liam put over the top of his Honda engined 4x4 Locost. Very neat solution.
James
bob
posted on 28/3/11 at 11:01 PM Reply With Quote
Are the latest MK's the same as the chassis picture posted, just a thought as i know the pictured chassis was made in 2001.
mad4x4
posted on 29/3/11 at 01:36 AM Reply With Quote
If we were to brace a chassis like that - small question ? Where do you fit the engine? there making it strong and inflexible but we also need to leave space for engines of differing sizes, the braces between the tunnel and the nose would foul my exhaust and my in lets on the zetec.....
Scot's do it better in Kilts.
snoopy
posted on 29/3/11 at 07:30 AM Reply With Quote
latest mk chassis
chassis1
chassis1
bob
posted on 31/3/11 at 08:14 PM Reply With Quote
Snoopy, Yes exactly my point although that isnt an Indy its the newer version. Not sure if they are making the Indy chassis the same as mine as 10 years ago.
[Edited on 31/3/11 by bob]
Mr Whippy
posted on 31/3/11 at 08:42 PM Reply With Quote
bare in mind though if you make the front super strong it might not collapse in a crash and instead make you passenger compartment into the crumple zone...
Steve Hignett
posted on 31/3/11 at 08:59 PM Reply With Quote
There are some pics of a triangulated chassis in the following thread:
http://locostbuilders.co.uk/viewthread.php?tid=132958
Although it's not complete at the time of the last photo...
snoopy
posted on 31/3/11 at 11:12 PM Reply With Quote
well this is a westfield chassis which i would assume most of us would say was suitably built
sebastiaan
posted on 1/4/11 at 06:27 AM Reply With Quote
I appreciate that the Westy chassis looka s lot like the MK (bar the short engine bay stiffeners and the rail across the scuttle area), but I'm simply after ways to stiffen the whole thing up a bit to further improve things.
And, as a sidenote: my MK is perfectly adequate for the odd sunday drive I use it for. It even self-centres (a bit.... ;-))
HowardB
posted on 1/4/11 at 06:37 AM Reply With Quote
Phil
that is one stunning engine bay!
[Edited on 1/4/11 by HowardB]
Howard
<<  1    2  >>
New Topic New Reply
