Author: Subject: Source for 4 way stretch vinyl
DaveFJ
posted on 31/1/11 at 10:19 AM Reply With Quote
As per Subject, does anyone know where I can get some 4 way stretch black vinyl in the UK?
only place I can find is in the US and shipping is expensive
re-making dash at the moment and going to need the 4 way stretch to get a neat finish, the usual 2 way stretch stuff just wont play nice with compound curves
Dave
steve m
posted on 31/1/11 at 11:25 AM Reply With Quote
I used normal vinyl for my seats and dash, and it all worked fine,
Just use a hairdryer to soften the materil slightly
My dash was made to sva rules
Pics in my photo archive
bi22le
posted on 31/1/11 at 12:08 PM Reply With Quote
yeah thats a tough one.
I cant help with supplier but can give plenty of advice, mind you I bet Im not the only one!!
Heat deffinatly helps.
Please read my ring story:
DaveFJ
posted on 31/1/11 at 12:19 PM Reply With Quote
would be fine for a flat dash but i decided to get all fancy with my new one and it's got compound curves and recesses and all sorts to try and cover.... rod for my own back and all that!
Dave
Hammerhead
posted on 31/1/11 at 12:22 PM Reply With Quote
try boynett fabrics
DaveFJ
posted on 31/1/11 at 01:14 PM Reply With Quote
just tried searching through boynett and got nowhere, a couple of leads both going to dead ends
cheers anyway
Dave
Hammerhead
posted on 31/1/11 at 04:00 PM Reply With Quote
sorry, must have gone under
Neville Jones
posted on 31/1/11 at 07:11 PM Reply With Quote
Try these people. They sometimes do the kit shows as well, and sell offcuts cheap. Good small carpet bits as well.
http://www.woolies-trim.co.uk/DEFAULT.ASPX
Nev.
Dave Bailey
posted on 31/1/11 at 09:36 PM Reply With Quote
Dave.... notice you have compomotive MO's .... Can you confirm the wheel size you have fitted with the offset on the rear?
thanks
Dave B
DaveFJ
posted on 1/2/11 at 09:58 AM Reply With Quote
Nev.
they only do 2 way stretch
Dave
DaveFJ
posted on 1/2/11 at 10:03 AM Reply With Quote
thanks
Dave B
Got 7"x16" on the front and 8"x16" on the rear... 205/45s front 245/30s on the rear
a bit overkill but almost impossible to unstick the rear in the dry (wets another matter!)
Had big issues with the rears as i ordered them with an offset i calculated and after i had recieved everything alse they conatcted me to say they couldnt do the offset i asked for. the resulting wheels stuck out of my arches by 15mm so i had to cut and space my rear arches with 2 weeks to go to SVA!
will have a looksy and see if i can work out what offsets i have/wanted as i cant remember right now sorry
Dave
bigandy
posted on 1/2/11 at 10:28 AM Reply With Quote
Try Martim in Cheshire. They had a huge range of vinyls, leathers, cloths, all sorts when I went there to choose the upholstery for my campervan.....
Dammit! Too many decisions....
DaveFJ
posted on 1/2/11 at 10:45 AM Reply With Quote
Have emailed martrim - awaiting a response
Dave
DaveFJ
posted on 18/3/11 at 01:49 PM Reply With Quote
Finally got some suitable vinyl after months of looking...
Amazingly I found what i wantedfrom a supplier in Ipswich! couldnt beleive it
anyway they seemed really friendly and supply all sorts of funky vinyl and also carpeting and now Fibre glass supplies!
highly reccomended
AS-Trim
Dave
