<<  1    2  >>
Author: Subject: Overfueling bike carbs
posted on 21/6/11 at 11:04 AM Reply With Quote
Have you checked the slide operation? All move up and down correctly?
Stupid Q? but what state are the air pipes that come out betwix 2&3 and 3&4? Not blocked? free to air?
posted on 21/6/11 at 12:59 PM Reply With Quote
One previous question you didn't answer (I think!) was - "Is the engine running properly at the moment, ignoring the smell of petrol?"
The reason for asking is - if the engine's running well then the state of the jets may be irrelevant and the problem's elsewhere. However, if it's running rough, using petrol like there's no tomorrow, or similar, then maybe fuelling is a problem.
You could try checking the colour of the plugs - get the engine nicely warmed up, give it a bit of welly here and there, then on a quiet road floor the clutch and turn off the ignition. Once you've stopped whip out a plug or two (hot, hot, hot!) and check their colour. This is a crude and unreliable test, but if the electrode is black and dripping with petrol you are undoubtedly over-fuelling. If they're a nice biscuit colour then you're roughly in the right ball park.
A couple of dumb but basic questions
- are there any signs of fuel dripping from the carbs when the engine's stopped but the ignition's on? I'm thinking of stuck and/or dirty float valves that aren't shutting properly when the chamber's full.
- is your passenger compartment fully sealed off from the engine compartment? You might be smelling normal engine fumes that you wouldn't if everything was screened off.
(I'm working on the principle that it's worth trying the simple solutions before getting onto the tougher, more expensive solutions!
40inches
posted on 21/6/11 at 01:20 PM Reply With Quote
Have the carbs been stripped before? Float level OK?
Craigorypeck
posted on 21/6/11 at 06:18 PM Reply With Quote
Easily the best thing to do is get an afr hooked in... if your gonna home tune.
can get a complete second hand set up off ebay if you keep an eye, or new if you wanna spend 150-170 quid,
I went with the innovate lc-1, quite fiddly to wire up, the uego one looks simpler..
Anyhow- it takes all the guess work out of tuning carbs, idle is easily set then get the main jet right at wot redline and then work back ways through the revs by adjusting needle height.
I too have ZX9R carbs, C1 jobs, on my 16v 2.0, I have 135 mains with ACs blocked, lift holes reduced 1mm, afr is spot on at all revs. I'm running red top and filterking with no issues.
Make sure they are positioned at the right angle too... Also just noticed you have a bike pump? They are interrupter type (unlike most fuel pumps which just whirr away all the time) which means they only tick when the carbs need fuel. So with the engine off and pump working it shouldn't be ticking at all, if it is there is a leak somewhere.
[Edited on 21/6/11 by Craigorypeck]
scoop
posted on 21/6/11 at 06:29 PM Reply With Quote
The car is running okay otherwise as far as i know. The sierra pedal box ive fitted has left a way for the engine fumes to get into my footwell.
The carbs are only two years old from Bogg Bros and went back to them in march this year for a clean up. Ive only done 350 miles! Everything moves smoothly and the needles are on the lowest setting barr one. They will insist on setting them with the mixture screw turned out 2 1/2 which is far too rich.
I think its got to be the jet size from all the information everyone has gratefully passed on.
Rather than guessing what i need ive come to the conclusion that i'll leave it all to the proffesionals and book it into Frosties next week weather permitting.
scoop
posted on 21/6/11 at 06:34 PM Reply With Quote
Craigorypeck, what do you mean when you say lift holes redused by 1mm?
I changed the plugs yesterday and the ones i took out were more blacker than brown. I will go out and check the new ones now though.
posted on 21/6/11 at 06:48 PM Reply With Quote
If you're seeing blackish plugs then you are probably overfuelling. I think you're right - a trip to a rolling road is your answer.
Who is/are "Frosties"?
scoop
posted on 21/6/11 at 08:25 PM Reply With Quote
Frost Motors in Ipswich. He used to work at Scole Engineering im told. Hes got the only rolling road and the skills in Suffolk to do it im told. Have a look at www.fmsauto.co.uk
I forget who mentioned that the midrange was basically controlled by the level of the floats and mine did seem hesitant about 3 to 4k so i raised them a notch and have just been out again. It is improved
The plugs still dark brown/black.
Thanks everyone for your help.
norfolkluego
posted on 21/6/11 at 09:45 PM Reply With Quote
Okay. Now we're getting somewhere. I understand that webber jets fit these carbs. Which ones do i get, DCOE?
[Edited on 21/6/11 by scoop]
Buy proper bike jets if you need them, way cheaper than Weber, they'll be available from any motorbike shop.
scoop
posted on 22/6/11 at 05:46 AM Reply With Quote
Cheers for that. The webbers are only a couple of quid each so i look forward to the lowercost items
Craigorypeck
posted on 22/6/11 at 06:52 AM Reply With Quote
It reduces the speed at which the slides lift, i had overfueling at lower revs when throttle was applied. this helped a bit. TBH I'd need custom needles made but doubt that will happen anytime soon.
Check out post 17 in this link, it has good info,
http://www.turbosport.co.uk/showthread.php?103402-X-flow-on-Yamaha-R1-carbs
[Edited on 22/6/11 by Craigorypeck]
mcerd1
posted on 23/6/11 at 07:34 AM Reply With Quote
scoop's pics
scoop
posted on 25/6/11 at 10:03 AM Reply With Quote
Just rung Bogg Bros and they tell me the jets are drilled to 1.65mm not 1.8 so seems strange that my carbs are overfuelling?
Bowers919
posted on 13/7/11 at 11:38 PM Reply With Quote
bike carbs on 1600 x-flow
I have 1600 xflow engine running bike carbs, fitted them and ran them with facet fuel pump and regulater, but it would not rev straigh out.. it stuttered at 4,700rpm when you put the pedal to the floor, so i took the regulater out and still had the same problem :-s
ive tryed putting a small storage tank just before the carbs to see if its the lack of fuel at high revs but it only made a slight change, it would stutter at 5,500 rpm then harsh accelerating.
the only time it revs out straight is if u accelerate steady but thats no fun :-(
any idears?? :-/ :'( thanks
posted on 14/7/11 at 06:36 AM Reply With Quote
"Smell of petrol" isn't so much a clue as a flashing illuminated sign ----- the float bowls are flooding.
Getting the jets a bit wrong won't cause a smell of petrol in the engine bay.
posted on 14/7/11 at 06:52 AM Reply With Quote
I had a very similar effect when I first fitted bike carbs - accelerating quite well but losing power massively at anything over 4k. When I finally got an air-fuel ratio (AFR) meter onto it I found that the mixture was far, far too rich at wide open throttle (WOT). After reducing the jet size from 1.6mm to 1.3mm the AFR was near-enough perfect when accelerating hard (slightly rich).
But it would be wise to get your car onto a rolling road, rather than just try this out, as your problem may not be the same! At least get an AFR meter and a mate to watch the readings as you go down the road.
<<  1    2  >>
