Author: Subject: front spoilers F1 style
Murphy
posted on 14/11/11 at 10:51 PM Reply With Quote
Hi
R1 locost very light at front end under acceleration but stable at steady high speed.
Will a front spoiler F1 style help?
If so where could I get one.
And I am sure it would look AWSOME.
Thanks all, John
blakep82
posted on 14/11/11 at 10:56 PM Reply With Quote
not really, no, they work at higher speed, and your problem is at lower speeds, so the faster you're going the better it will work.
think suspension set up might be a better place to start
________________________
loggyboy
posted on 14/11/11 at 11:03 PM Reply With Quote
Get the car professionally set up and cornerweighted. No reason a 7 style car should be light on the front end, even a BEC.
ReMan
posted on 14/11/11 at 11:29 PM Reply With Quote
Also (and not to patronise you ) but assuming it was OK before you got it , make sure the tyres are at a BEC pressure at the front somwhere around 18psi..
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
StuartBJ
posted on 15/11/11 at 12:05 PM Reply With Quote
Originally posted by Murphy
Hi
Thanks all, John
Hi John,
Aero won`t help you at low speed but if you still decide you want some aero induced front end grip (for whatever reason) perhaps "canards" may be more suitable. .....but remember aero only works at higher speeds and thus my learned colleagues above are right with respect to your lack of mechanical front end grip.
Start by looking at your tyre options/pressures, camber/ and toe first
All the best
Murphy
posted on 15/11/11 at 10:32 PM Reply With Quote
I appreciate the replies. Not patronised at all as I am taking in all this on a first time basis. Reading everything I can too.
Cheers everyone
