Author: Subject: 2006 r1 hot oil pressure
charlie_pank
posted on 31/3/12 at 09:47 PM Reply With Quote
Anyone know what I should expect to see? I'm getting around 80-90psi at 8000 rpm. Seems v. high to me.
Smigga
posted on 31/3/12 at 09:53 PM Reply With Quote
Dont know if it relates but my Blade runs similar...
Dave
adithorp
posted on 31/3/12 at 10:40 PM Reply With Quote
Sounds about right. How hot was it? Mine makes about 10psi/1000rpm @80c. It's very low at idle (hardly lifts the gauge) when hot but about 60psi when cold. It's low idle pressure that worries most people.
http://jpsc.org.uk/forum/
charlie_pank
posted on 1/4/12 at 06:22 AM Reply With Quote
I'm ok with the idle pressure of 10-20 psi @80degrees C, I was more alarmed by the pressure going up to over 90 when pressing on!
kjouk
posted on 1/4/12 at 08:28 AM Reply With Quote
The pressure relief valve is spec'd at 87-99 psi so within normal range of that. The service manual test is 33psi @ 5000rpm with 80-90C oil temp.
charlie_pank
posted on 1/4/12 at 01:43 PM Reply With Quote
I reckon my OPG might just over-read a little. As you say the Haynes manual states an opening pressure of up to 99psi
MK9R
posted on 1/4/12 at 03:25 PM Reply With Quote
That sounds ok to me, similiar to mine.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
