Author: Subject: Wind Deflectors
digiman
posted on 15/4/12 at 07:24 PM Reply With Quote
Wind Deflectors
Has anyone tried these wind deflectors? And are they any use?
Thanks Chaps
Caterham Wind Deflectors | eBay
ian locostzx9rc2
posted on 15/4/12 at 07:33 PM Reply With Quote
Wind deflectors
Hi made a set for my bike engined striker many years ago and it made a big difference.
KitCatE1
posted on 15/4/12 at 07:35 PM Reply With Quote
wouldn't they just flap about without friction hinges?
snapper
posted on 15/4/12 at 08:06 PM Reply With Quote
I started without a screen,
added a screen
Big difference
Added deflectors, looked good but didn't make much of a difference
Added doors
Big difference
I eat to survive
I drink to forget
Chippy
posted on 15/4/12 at 10:00 PM Reply With Quote
I fitted wind deflectors before fitting the doors, bloody waste of time and money, they made little or no difference. IMHO Ray
posted on 16/4/12 at 07:35 AM Reply With Quote
I fitted these to my screen:
Wind deflector
Wind deflector
They didn't get rid of the turbulence, but they did reduce it quite a lot.
I built my car for the open-air experience, so I don't want to be closed in by doors!
posted on 16/4/12 at 09:35 AM Reply With Quote
They do make a difference. I homebrewed some and stuck them to my Locost. But yes, the problem is that they can flap about and mine actually rode up on the hinges which wasn't the plan! I ended up using some proper Locost string to hold them down
posted on 16/4/12 at 06:18 PM Reply With Quote
I made some using an offcut of Lexan from my local plastics supplier that are a bit wider than the Caterham items and are fixed solidly to the screen pillars . IMHO they do cut down the buffeting and only cost pennies
digiman
posted on 17/4/12 at 09:36 AM Reply With Quote
I've just tried to knock some up with some 4mm polycarbonate, but made a real hash of cutting it.
Any suggestions on the best way to cut rounded shapes?
posted on 17/4/12 at 09:48 AM Reply With Quote
I roughed mine out with a hacksaw (maybe my jigsaw with a fine blade - can't quite remember) then filed the edges to shape. Needless to say that you should take care not to scratch the plastic while doing this! I left the protective film on, and put padding in my vice jaws. Got rid of as many scratches as I could on the edge by going to finer and finer files (I have many!).
Once the shape was right I sanded the edge using progressively finer grades of emery paper, right down to the very finest (crocus paper?). Then I polished the edge with Farecla G4 (used for cutting back and smoothing new paint).
Sounds like a lot of work, but it was just a couple of hours idly fiddling around in the garage.
[Edited on 17/4/12 by David Jenkins]
