<<  1    2  >>
Author: Subject: which bike carbs!!
cal
posted on 23/11/12 at 08:55 AM Reply With Quote
The zx7 has a similar setup for ram air tubes. There is no requiemt to alter the float bowls
ross05
posted on 23/11/12 at 09:08 AM Reply With Quote
carbs
poorscoucer,bring it on the more posts the more info I get
So I should get the bike carb fuel pump or a regulator for the existing pump,ok will look into that.
cheers guys
mcerd1
posted on 23/11/12 at 09:41 AM Reply With Quote
Originally posted by ross05So I should get the bike carb fuel pump or a regulator for the existing pump,ok will look into that.
bike carb pump - bike carb's don't like being force fed fuel
the zx9r / zx6r type pump's are quite neat (should be quite cheap from a bike breaker)
Fuel pump mounting, close up2
(thats '40inches' pic not mine)
mcerd1
posted on 23/11/12 at 09:44 AM Reply With Quote
Originally posted by Poorscousertommy
Excuse the ignorance, but would the same setup be suitable for a Duratec? (Sorry for the hijack!)
yes, but with a different manifold obviously
infact carb's that size (38 - 40mm choke) should work with just about any 4 pot engine between 1.8 and 2.5l (depending on the sate of tune of course...)
splitrivet
posted on 23/11/12 at 10:02 AM Reply With Quote
If your using a low pressure pump at present then you shouldnt need to change it. Why are you outing the webbers though cant see you gaining much other than better MPG.
Bob
[Edited on 23/11/12 by splitrivet]
ross05
posted on 23/11/12 at 12:40 PM Reply With Quote
carbs
Only changing the 40's because should be 45's with 5 progression holes and the next best solution looks like zx9r bike carbs...
mcerd1
posted on 23/11/12 at 01:54 PM Reply With Quote
one of these will help you make the airbox / filter backplate easy
KAWASAKI ZX9R E1 2000 UK MODEL AIR INTAKE RUBBER &' MOUNTING PLATE COMPLETE
<<  1    2  >>
