Author: Subject: luego viento front grill
VIENTOV8
posted on 24/12/12 at 02:45 PM Reply With Quote
as anyone got or know where to get the front nosecone chrome grill for the viento?
andrew.
tomgregory2000
posted on 24/12/12 at 05:20 PM Reply With Quote
You could ask luego sports cars
They are on facebook
wilkingj
posted on 24/12/12 at 05:38 PM Reply With Quote
I got a bit of cross hatched stainless grill from Porteous Fabrications (on Ebay)
I emailed him first, he cuts to size and then gave me the ad number on Ebay.
Vertical / horziontal checking is cheapest Uses least metal in a sheet.
Diamond checking is more expensive due to the wastage.
I went for the diamond polarisation. Its all the same grid, just just cut to your liking.
I then held it all in place with Sika flex. Has been in there about 7 years now!
A lot cheaper than the Std Luego Grill.
Its your choice if you think one looks better than the other.
Also, I recon a fine grid works better by keep the stones from denting / holing your nice expensive radiator
Cant remember if it was 1 or 2mm thick, and I think was a 10mm grid section.
Also mine was welded grid, not woven.
Hope that helps.
Ebay Grill
Ebay Grill
Luego's Factory cars..
Viento v Velocity (Size wise)
[Edited on 24/12/2012 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 24/12/12 at 06:10 PM Reply With Quote
Didn't someone put a post on the forum somewhere about a fine grill restricting the airflow to the rad? Don't know if there are any photos on here on snuggs's grill which looks rather smart? Can't remember seeing 2 Viento's with the same grill?
wilkingj
posted on 25/12/12 at 11:52 AM Reply With Quote
Mel, You're right, but a 6 or 8mm plus grid size wouldnt cause an issue. Mine was 10mm or poss 12mm. Its that really fine close grid / perforated ally mesh that is not too god on a Viento. That sort of mesh looks a bit cheap as well.
Again, all depends on what Rad, Fan, and Engine.
Ducting the nosecone into the Rad makes a huge difference.
Just my 2d's worth
Best Regards
Geoff
VIENTOV8
posted on 25/12/12 at 04:48 PM Reply With Quote
hi thanks for the help, mine as a fine mesh black grill on at the moment, but i like the look of the chrome tube grill that luego did.
thanks andrew.
Scotty
posted on 27/12/12 at 11:39 AM Reply With Quote
Hi
I bought one but never fitted. Its an original from the days when grant was running luego. Will get photo and post if you are interested in buying
PLEASE NOTE! All comments made by this person are to be considered "Tongue in Cheek" and are not meant to be taken seriously in any way - so there!
VIENTOV8
posted on 27/12/12 at 03:59 PM Reply With Quote
chrome grill
hi yes i would be interested, please send photo to andrew_tolley2005@yahoo.co.uk how much do you want for it including p/p?
thanks andrew.
Scotty
posted on 27/12/12 at 05:21 PM Reply With Quote
Ok. Will do tomorrow
Scotty
posted on 4/1/13 at 11:10 AM Reply With Quote
piccys emailed
let me know if you dont receive
