<<  1    2  >>
New Topic New Reply
Author: Subject: Advise please
p2ccolo
posted on 10/2/13 at 09:19 PM Reply With Quote
Hi guys, went to see the car today, all seemed ok, and I really liked it, however I noticed a small thick amount of white "mayo" in the oil cap, and a very tiny little puddle of what looked like oil in what I think is a core plug on the side of the engine? I took a photo which I will try to upload. The owner seems certain its not an issue and that its quite normal to get this build up of white stuff on the filler cap due to the weather and lack of use and that the slight leak in the core plug is nothing and just needs a new part to sealant which he said was nothing to worry about.
Does this sound right to you, should I be concerned about head gasket?
p2ccolo
posted on 10/2/13 at 09:27 PM Reply With Quote
[Edited on 10/2/13 by p2ccolo]
bi22le
posted on 10/2/13 at 11:03 PM Reply With Quote
the different power bands could be SC clutch engaged or not which i think some eaton chargers do have but not rotrex or stock gze (4age supercharged ).
i would of thought a well mapped car would run like dog though if it was in a non SC setup. some one may know more. either way that switch would stay in one position for me, on !
if you get no advice on this post about milk and leak core plug then start a new post. its quite crucial you get an answer.
my gut feeling is any milk is bad milk.
oh and the polished rocker cover only means it is 16v. no tell tail of what SC it has or history. but if it was originally mr2 SC engine the cover would say supercharged on it so why grind the gloating points off?
dont mean to sound negative, just being analytical.
[Edited on 10/2/13 by bi22le]
Please read my ring story:
R1_striker
posted on 11/2/13 at 11:41 AM Reply With Quote
the standard toyota superchagers do have a clutch'd pulley, but as bi22le a well set up would run like a dog if the charger was turned off.
that core plug in the head seam to be where the dizzy used to be, so not a great problem if there is a dribble of oil. Would of thought thats easy enough to seal.
Why dont you try giving raw a ring, they may be able to help or sell you a proper car lol
small tax, small insurance, huge laughs
JimSpencer
posted on 11/2/13 at 12:11 PM Reply With Quote
Hi
IF the car has been done by Raw then the power output is quite believable, not so sure why you would want it switchable and I would want to know what ignition set up was on it to make the mapping switch over at the same time to make it run OK.
Rather than chat to the owner - get the registration and ring Raw, speak to Martin and find out what they've done with it
That core plug location seems to collect a dribble of oil - personally I reckon you'll find its weeping under the corner of the rocker cover and just collecting there, mine did anyway
Think the rocker covers are aftermarket ones (you used to be able to get ones from Japan with 'Cosworth' cast into them to make it look like a BDA!) have seen plain alloy ones before but don't know where they come from.
Agree with the ride height queries, looks wrong - but the bloke might have loads of sleeping policeman down his way - or it could be a bit high as it's got a standard sump on it - you can get a lowered 'big wing' sump easily and cheapily enough though (Raw can supply) or it's possible, but expensive, to dry sump them (you'll only need the latter if it's going to see a Track with slicks or ultra sticky track day rubber.
You can get a little bit of gunge under the oil cap if it's been stood a while as it's not unknown for a bit of damp to get in there, have seen that a couple of times - but it's not much - literally anything more than a smear of it and I would be wanting to do a sniff test on the coolant.
Hope this helps
p2ccolo
posted on 11/2/13 at 02:31 PM Reply With Quote
Thanks for all of the responses. Spoke with RAW (Very nice guys indeed and very helpful!) they confirmed that the engine work would not have been carried out by them however some of the other bits and pieces may well have done (I have seen receipts of around £4k for various bits of work carried out by them but no receipts for engine work), but they dont rememebr the car, though this is not suprising seeing as it would have been 10 years ago.
Martin at Raw also said that the white gunk can be quite common in these engines and probably not anything to worry about.
He did however say that he doubted the claimed BHP.
As for ride height, when I looked at the car on a flat surface on the weekend the height was around 5-6 inches from the ground, but was roughly level/ the same distance form the ground at the front and rear. He said is brother had adjusted the height using the settings he rang up stuart taylor motorsport and acquired.
Bit of a dilemma, now for me I suppose. I think for the information that Ive had head gasket should be ok based on those symptoms, but parting with this much cash and no comeback obviously make me a bit weary.
I like the car and left a deposit, with the view that next weekend we would be going out for a test drive (weather permitting) and provided it drove well I would buy it, which if this is still a good car I would want to do, but sinse I am new to kit cars and by no means knowledgable on mechanics, really weary of buying a bad car.
<<  1    2  >>
New Topic New Reply
