<<  1    2  >>
Author: Subject: Help - Angle grinder debris on glass
vindi93
posted on 30/5/17 at 04:44 PM Reply With Quote
Going to try this
http://www.glasspolishshop.com/glass-scratch-repair-starter-kit-gp-wiz-system
Going to try this as i allready have a variable polishing mop and 50odd quid is cheaper than a new windscreen
posted on 30/5/17 at 04:59 PM Reply With Quote
I've used something similar to remove scratches on the windscreen of my last car. It did a decent job, but there are a few things to bear in mind:
1. You might see some visual distortion where the glass was polished, especially if it's in your line of vision - you are removing glass, after all.
2. You have to keep the area wet and must keep the polishing head moving - if you concentrate your efforts in one area, or let it run dry, you can generate too much heat and crack the glass. The glass does get warm.
3. It's very messy - I sprayed polishing compound all over the garage! I had taped polythene sheet all over the car's bodywork, but some still worked through. You have to be very careful (and quick) to get the compound off paint.
Coming back to the original question - this may remove grinder spatter marks, but you might still see where you've polished. Worth a try though...
The older I get, the better I was...
Vmax1974
posted on 30/5/17 at 05:12 PM Reply With Quote
Ok try my trick
1) scrape excess off with a glass scraper
2) when the wife starts moaning roll eyes
3) get a girlfriend
4) divorce wife
5) sit back and relax as suddenly the shards of metal in the glass are the least or her problems
Supplier of haynes roadster bodywork visit https://m.facebook.com/vmaxcomposites/ or u2u me
posted on 4/6/17 at 08:04 AM Reply With Quote
Just use Clay bar and detailing spray before going in with anything abrasive.
[I] What use our work, Bennet, if we cannot care for those we love? .
Slimy38
posted on 4/6/17 at 03:29 PM Reply With Quote
I mistakenly bought a glass lens for my welding mask, thinking it would be tougher than plastic. After about five minutes it had got so pitted and scored that I had to bin it!!
<<  1    2  >>
