Author: Subject: Can anyone machine these out of 3mm Ali
corrado vr6
posted on 20/5/13 at 02:43 PM Reply With Quote
Hi there,
Is anyone able to machine me these? I need 6 rings in total all with a hollow centre so I'm left with a 12.5mm ring
They need to be made from 3mm Ali
Obviously willing to pay
Thanks in advance
Greg
http://r1indy7.wordpress.com/
Matt_C
posted on 20/5/13 at 03:00 PM Reply With Quote
Machining would be a very expensive option. Would be much cheaper and easier to have them laser cut or waterjet cut from ali. Both of these are always a cheaper option than machining on any 2D shape.
Places I use would be too far away from you, if you just google it I'm sure you can find local places.
trextr7monkey
posted on 20/5/13 at 03:15 PM Reply With Quote
Fly cutter in drill and just go steady! I don't think we have any ali that thick knocking about could check in the morning, we made similar things once for a bloke changing down lighters in his 70's house
What is their application, tolerances, required finish etc?
atb
Mike
corrado vr6
posted on 20/5/13 at 03:48 PM Reply With Quote
There just to mount some lights strangley in a jago!
They won't be seen so haven't got to be to special, but i don't have the tools unless I chain drilled then filed them to shape which would take a while to do 6
They haven't got to be mm perfect just there abouts really
Edited to say I could supply a sheet of Ali if its something you think you could do?
[Edited on 20/5/13 by corrado vr6]
trextr7monkey
posted on 20/5/13 at 04:38 PM Reply With Quote
just sent a u2u
T66
posted on 20/5/13 at 04:59 PM Reply With Quote
Isnt there a locoster who has a water jet cutter ?
matt_claydon
posted on 20/5/13 at 05:31 PM Reply With Quote
As above, don't machine, use either laser or waterjet. I think it's andyw7de on here who has a waterjet.
You could do it yourself with two hole saws, although you won't get exactly those dimensions. 76mm and 86mm are readily available, but pretty sure I've seen 90mm.
T66
posted on 21/5/13 at 10:34 PM Reply With Quote
http://www.mig-welding.co.uk/forum/showthread.php?t=40595
