Author: Subject: Drilling 42mm Hole
prelude1980
posted on 9/6/14 at 07:21 PM Reply With Quote
Drilling 42mm Hole
i need to drill a load of 42mm holes in 2mm aluminum,
Normally i'd used a stepped cone cutter but the largest i have goes up to 40mm
I don't like holesaws much as i find they tend to move around a lot.
Also i can't use a pillar drill so can only use a corded drill.
Any ideas on how to do this easily?
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
HowardB
posted on 9/6/14 at 07:46 PM Reply With Quote
cone drill, and then a file? or invest in the next size drill,. or ask a friend?
Howard
Theshed
posted on 9/6/14 at 07:48 PM Reply With Quote
You could use a Q Max type sheet metal cutter - loads on ebay but not a cost effective one hole solution....whereas that half round file you know you have lurking behind the tin of elbow grease...
prelude1980
posted on 9/6/14 at 07:52 PM Reply With Quote
i have about 100 holes to do so that q max cutter is an idea if i can find the correct size
gets you.
DIY Si
posted on 9/6/14 at 07:54 PM Reply With Quote
Is something like a tank cutter any good? No idea how much they are though!
Sun Tzu, The Art of War
prelude1980
posted on 9/6/14 at 07:57 PM Reply With Quote
if i had a pillar drill maybe but trying to hold that steady in a drill gun maybe a bit tricky?
gets you.
mark chandler
posted on 9/6/14 at 08:00 PM Reply With Quote
You need one of those cutters where you have a former that pushes into a tube, like a void bush removal tool with a cutting face.
bi22le
posted on 9/6/14 at 08:05 PM Reply With Quote
Kind of the thing I was thinking of but also dont know the name.
Its a circular cutting press that you drill a smaller hole in the middle (10mm) and then wind the two sides of the tool together from separate sides of the sheet. It then cuts the hole. Kind of like a circular tin snip. I dont know, maybe make one!
Please read my ring story:
mark chandler
posted on 9/6/14 at 08:07 PM Reply With Quote
Like this
eBay Item
prelude1980
posted on 9/6/14 at 08:14 PM Reply With Quote
Like this
eBay Item
i think that would be perfect
Many thanks for all the help
gets you.
wicket
posted on 9/6/14 at 08:48 PM Reply With Quote
That is a Qmax cutter
posted on 9/6/14 at 09:05 PM Reply With Quote
Yup. That's a qmax. Grease the thread and piece of piss. I have quite a few now. Lovely things.
ashg
posted on 10/6/14 at 09:31 AM Reply With Quote
Plasma cutter with a compass attachment
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
