<<  1    2  >>
Author: Subject: Pre IVA photo (lots of 'em)
AndyW
posted on 25/1/15 at 11:00 AM Reply With Quote
I had to cover this whilst at IVA, luckily I had trim with me and the tester allowed me to do so!!
theduck
posted on 25/1/15 at 01:48 PM Reply With Quote
Is that edge not within the exempt Zone inside the wishbones?
AndyW
posted on 25/1/15 at 03:13 PM Reply With Quote
My tester picked up on it and wanted it covered
CosKev3
posted on 25/1/15 at 04:04 PM Reply With Quote
Looks to be outside the 'box' you would make going from bottom wishbone to top wishbone to me?
luke2152
posted on 25/1/15 at 09:17 PM Reply With Quote
Thanks all for the pointers. Should be enough to keep me busy til the test. Tunnel is fully riveted so I'll just wait and see what happens with the carabiner and get on with the other bits.
[Edited on 25/1/15 by luke2152]
AndyW
posted on 25/1/15 at 09:39 PM Reply With Quote
Correct, hence why I posted that my inspector picked up on it!
Good luck to the OP on the fixes.
Slimy38
posted on 25/1/15 at 09:51 PM Reply With Quote
If I was an inspector I would fail that handbrake carabiner. Those non locking types aren't reliable even in their intended location on a climbing harness, to have it here can't be good.
There must be hundreds of other solutions, an immediate thought would be a proper handbrake t piece probably obtained for a few pence.
indykid
posted on 26/1/15 at 07:31 PM Reply With Quote
Are jubilee clips on fuel lines still a fail?
I would expect your execution of the brakes, both hydraulic and handbrake would draw heavy scrutiny to the rest of the car. The flexis need to mount with bulkhead fittings to brackets on the frame and the number of pipe joints, especially pipe on pipe joins would be a real concern.
The brake pipe at the rear of the transmission tunnel looks like it's starting to kink.
<<  1    2  >>
