<<  1    2  >>
Author: Subject: Jaguar V6 Injectors - under size?!
Badger_McLetcher
posted on 7/2/17 at 07:36 PM Reply With Quote
I ended up using GSXR 1300 throttle bodies, mounted on a homemade manifold and modified to accept Z20LET injectors fed by a custom fuel rail
If disfunction is a function, then I must be some kind of genius.
40inches
posted on 7/2/17 at 08:41 PM Reply With Quote
Went for the easy option then?
Badger_McLetcher
posted on 7/2/17 at 09:24 PM Reply With Quote
Haha I realised I while back that I never seem to make life easy for myself
CosKev3
posted on 31/8/18 at 08:36 PM Reply With Quote
Any pics of your progress on this available?
40inches
posted on 1/9/18 at 09:45 AM Reply With Quote
Bottom of this thread Kev
https://www.locostbuilders.co.uk/viewthread.php?tid=198643
AdrianH
posted on 1/9/18 at 10:17 AM Reply With Quote
Am I wrong in thinking that some injection systems injected on the non fire stroke into the inlet side and then just before bang injected a second time before the fire, hence smaller injectors could be used. A bit like the spark plugs fire on two out of four cylinders at a the same time, but it makes no difference as one cylinder is exhausting as it happens.
I think it's in the four stroke performance tuning book.
I guess it depends on the ECU in use.
Adrian
Why do I have to make the tools to finish the job? More time then money.
Badger_McLetcher
posted on 1/9/18 at 01:08 PM Reply With Quote
Adrian
That's basically batch injection, where a number of injectors are "batched" together and will fire simultaneously - since they operate on different cylinders they give the effect you describe. Not so sure about it reducing the size of the injector so much, but that would appear to be logical. From memory one of the drawbacks of the "wasted" injection cycle is that the air is probably going to not be moving fast (if at all) and the fuel may drop out of suspension.
Regarding pictures, I'll try to get some more detailed ones today but I'm still in the middle of my re-work, so no promises!
[Edited on 1/9/18 by Badger_McLetcher]
CosKev3
posted on 1/9/18 at 01:12 PM Reply With Quote
Looks a nice set up,but not for a standard bonnet!
<<  1    2  >>
