<<  1    2    3  >>
Author: Subject: Ford rear disk conversion
Daf
posted on 25/4/15 at 08:08 PM Reply With Quote
Evening all!
I've had some brackets laser cut to mount MX5 rear calipers to sierra rear hubs, these clear my 13inch wheels with plenty of space and use fiesta Mk1/2 221mm front disks.
I had these cut for myself but it was the same price for two for me or 28, so I got 28 made! I'm not looking to make any money really just seems a shame for them to sit on my garage floor when others could use them.
I wont lie - they're a b****r to fit as the caliper carrier bolts sit between the bracket and where it mounts to the sierra hub so you need to put disk and caliper on together, it's not a problem but you really need 3 hands! (Or two hands and a lot of swearing like I just did!)
You do have to grind a little away from the back of the caliper carrier, about 1mm or so, also I'm running the calipers upside down so that it's a better route for the handbrake cable - makes caliper bleeding more difficult. They will mount the right way round on the bracket if you want.
£10 per pair + P+P, I'll also be at Stonleigh (Sun) so save on the P+P if you want
[Edited on 25/4/15 by Daf]
[Edited on 26/4/15 by Daf]
Dick
posted on 25/4/15 at 08:40 PM Reply With Quote
Message sent
snapper
posted on 26/4/15 at 07:09 AM Reply With Quote
Put a set aside for me pls
I'll PM and we can work out postage
Ta
I eat to survive
I drink to forget
Rosco86
posted on 26/4/15 at 07:55 AM Reply With Quote
So you still use the std sierra disc? Very interested, whats the weight difference between the sierra caliper and the mx5 caliper?
Daf
posted on 26/4/15 at 08:10 AM Reply With Quote
snapper - one set put aside with your name on
Rosco86 - I'm using Fiesta front disks, I dont know about the weight but I couldnt get the sierra set up to fit under my 13 inch minilites so I came up with this solution
se7ensport
posted on 26/4/15 at 11:03 AM Reply With Quote
Is this a disc to disc or drum to disc conversion? if it uses the drum hubs I'm potentially interested.
Daf
posted on 26/4/15 at 11:30 AM Reply With Quote
Mine was a drum set up before - you might need to have the hubs turned down to get the disk to fit over them though, I believe there is more than one kind of hub - I'm no Ford parts bin expert it's just what I read when doing the research for this
se7ensport
posted on 26/4/15 at 07:34 PM Reply With Quote
I'll take a pair, u2u me Paypal address and price to post.
Alex
Dino
posted on 29/4/15 at 10:38 AM Reply With Quote
Alex
Was the conversion easy?
Daf
posted on 29/4/15 at 10:55 AM Reply With Quote
It's a bolt on conversion, the only things you need to do are remove some metal from the back of the calliper - about 1 to 2mm. I did this with a flap wheel on the grinder but it would be better to do it with a miller.
Also from what I understand there are two types of ford hub - the fiesta disk will go onto one of them no problem the other needs to be turned down as the diameter is a bit big. other than that it all just bolts together
Daf
Dino
posted on 29/4/15 at 11:00 AM Reply With Quote
Sounds simple enough and maybe something worth looking at in the darker months.
I gather U will be at Stoneleigh?
Hopefully we can meet-up and I can grab a pair.
Daf
posted on 29/4/15 at 11:06 AM Reply With Quote
Yep I'm there on the Sunday, I'll U2U you my phone number and you can give me a shout
mazie
posted on 29/4/15 at 11:38 AM Reply With Quote
Ill take a pair, wont be at stoneleigh even though i live 5 minutes away, unless you done mind me collecting from outside the park?
djtom
posted on 29/4/15 at 12:31 PM Reply With Quote
Yes please, I'll take a pair. Will need posting though, so I'll send a U2U to sort the details out.
Tom
Daf
Yep no worries, you can drive into the car park for free so I'll U2U you my number and you can give me a call - I can meet you in the car park sometime during the day
mazie
posted on 29/4/15 at 03:18 PM Reply With Quote
Thats Ace thanks chap. What day/days are you going?
cs3tcr
posted on 29/4/15 at 05:30 PM Reply With Quote
Daf,
A bit OT, but can you tell me the size and thread pitch of the caliper bracket bolts? I picked up a set of Miata brakes for my car, but didn't get the bolts to mount them.
Thanks,
Rod
Daf
posted on 29/4/15 at 06:35 PM Reply With Quote
Originally posted by cs3tcr
Daf,
Thanks,
Rod
No worries, they're M10x1.25
Daf
plus2s
posted on 30/4/15 at 02:19 PM Reply With Quote
Rear brake conversion
Hi will take a pair please. I will be at Stoneleigh on Sunday
Cheers, Paul
Daf
posted on 30/4/15 at 05:53 PM Reply With Quote
Cheers, Paul
U2U sent
stevepj
posted on 1/5/15 at 08:09 PM Reply With Quote
I'll take a pair too please.
Will be at Stoneleigh all weekend.
ChrisL
posted on 13/11/15 at 10:12 PM Reply With Quote
Have you got any pairs left? If so I'd like a pair...
Daf
posted on 14/11/15 at 09:14 PM Reply With Quote
Sorry they've all gone, the last few went on ebay a couple of weeks ago.
ChrisL
posted on 15/11/15 at 07:55 AM Reply With Quote
Shame, thanks for letting me know that they'd gone.
Daf
posted on 15/11/15 at 12:12 PM Reply With Quote
If we could get another 15 people together I would be more than happy to get another batch made up.
<<  1    2    3  >>
