Author: Subject: Are propshaft supports needed?
Piooly
posted on 15/5/15 at 12:54 PM Reply With Quote
Do you need supports for the propshaft for the IVA test? The ones for if your propshaft came off...
My test is in a couple of weeks and I would struggle to add them..
thanks
MikeR
posted on 15/5/15 at 01:14 PM Reply With Quote
no.
Smoking Frog
posted on 15/5/15 at 01:19 PM Reply With Quote
Prop catcher? No don't think so.
theduck
posted on 15/5/15 at 01:30 PM Reply With Quote
Nope, but still worth fitting them if you can.
joneh
posted on 15/5/15 at 01:36 PM Reply With Quote
Not needed but I'm fitting one each end. Don't think 1mm of alloy plate will stop 7kg of 6000 rpm ripping through my leg if it lets go!
Slimy38
posted on 15/5/15 at 02:04 PM Reply With Quote
It is disturbing how an obviously effective safety device is not included in IVA, but a sharp corner that a pedestrian might graze their leg on is an instant fail...
adithorp
posted on 15/5/15 at 02:09 PM Reply With Quote
Not an IVA requirement but a good idea if you can fit. Just needs to be enough to keep the prop close to aligned to prevent it flailing.
http://jpsc.org.uk/forum/
