Author: Subject: Wiring a Car - what material for a bus?
Ivan
posted on 25/3/16 at 07:55 AM Reply With Quote
I am busy rewiring the fuse box on my Cobra and want to make a bus with bolted wire takeoffs to the fuses to neaten the +ve side of the fuse box.
I have two suitable strips of metal - one Aluminium and the other Stainless steel - are either OK to use or should I get something else?
Bluemoon
posted on 25/3/16 at 08:09 AM Reply With Quote
Copper strip, wiped with Vaseline or silicone grease?
Aluminium will corrode, Stainless is a poor conductor...
Dan
balidey
posted on 25/3/16 at 09:33 AM Reply With Quote
This any good to you?
http://www.toolstation.com/shop/Electrical/d190/Electrical+Accessories/sd2620/Earth+Block/p63372
Dutch bears have terrible skin due to their clogged paws
Edwardo
posted on 25/3/16 at 09:52 AM Reply With Quote
I used these (although the 100A version) - either way they are still massively overated for the job:-
Auto & Marine Power Distribution Bus Bar 10 Way Screw - 150A
[img][/img]
[img][/img]
(The big red lead was just for testing something by the way)
I also used these for the earthing points rather than dodgy screw connections all over the frame:-
Neutral/Earth Bar JEW103A 100amp Brass Bar
Tony
Ivan
posted on 25/3/16 at 11:44 AM Reply With Quote
Thanks guys - I will see if I can get a copper bus or something suited from the local electrical supplier once the Easter weekend is over.
Any other ideas are also welcome.
Mr Whippy
posted on 25/3/16 at 12:37 PM Reply With Quote
just make sure it can't come off in a crash or touch any thing metal (bearing in mind the body could be distorted) if it comes off the battery with no main fuse to it all hell could let rip
indykid
posted on 25/3/16 at 01:09 PM Reply With Quote
Make sure it has a main fuse to it in any case
Toprivetguns
posted on 25/3/16 at 04:25 PM Reply With Quote
Very neat install - really like it.
[img][/img]
[img][/img]
Tony
Only drive as fast as your angel can fly... !
Ivan
posted on 26/3/16 at 09:29 AM Reply With Quote
Thanks to a suggestion from 02GF74 I will be making the bus from a piece of cut and flattened Cu water pipe. As suggested by him I can tabs from it or drill it and use bolted connections.
