Author: Subject: Toyota 4age Spark Plug Issue
ttalps2000
posted on 9/6/16 at 07:49 PM Reply With Quote
Is there any reason why my Toyota 4age should be blowing out a spark plug on cylinder 2 only in a very short space of time?
This is the second plug now and it has only been run a handful of times. The engine is running rich as i have not had it on the rolling road yet, but all the others have been fine.
The plug does not appear to be all oiled up etc and seems the same as the others when removed.
Any help would be great!
adithorp
posted on 9/6/16 at 08:26 PM Reply With Quote
Blowing out?
http://jpsc.org.uk/forum/
perksy
posted on 9/6/16 at 08:28 PM Reply With Quote
When you say "Blowing out" Do you mean it's actually coming out of the cylinderhead ?
If so a Damaged spark plug thread in cylinderhead would be the first check once you know its correctly tightened in the first place
ttalps2000
posted on 9/6/16 at 08:32 PM Reply With Quote
sorry wrong terminology, as in it is no longer working/sparking
posted on 9/6/16 at 08:58 PM Reply With Quote
Have you switched the coil packs between cylinders to see if the miss follows the coil pack.
ttalps2000
posted on 9/6/16 at 09:04 PM Reply With Quote
yep tried that last time, no difference. Change the plug and runs fine!
Put the plug in a different cylinder and it then will not fire on that cylinder
Dusty
posted on 9/6/16 at 09:43 PM Reply With Quote
Running rich kills plugs these days. Secondly unless you have done so already have the injectors out, cleaned and flow checked. I did this 2 years back on my zetec and had the worst at half the flow of the best with the other two in the middle somewhere. Explained a lot! New injectors were the order of the day. Maybe your injectors are like mine were.
ttalps2000
posted on 9/6/16 at 09:45 PM Reply With Quote
its on carbs lol. all been rebuilt etc though
Dusty
posted on 9/6/16 at 10:59 PM Reply With Quote
Well it won't be the injectors then I guess! Might still be a useful post for someone with a rough running plug spoiling injected engine.
SPYDER
posted on 10/6/16 at 12:26 AM Reply With Quote
Check for a loose carb jet on the offending cylinder.
ttalps2000
posted on 10/6/16 at 10:24 AM Reply With Quote
will have a look
