Author: Subject: headlamp pics and iva info please
chris_smith
posted on 22/12/16 at 07:34 PM Reply With Quote
anyone fitted these and got pics of them on the car please ?
and have you passed IVA without issue with pattern etc?
5" Complete Headlamp Satin Black For kit Car Classic
russbost
posted on 22/12/16 at 07:47 PM Reply With Quote
I would suggest asking CBS as they are the seller, it says they have a flat beam which is fine for IVA providing it is genuinely flat & doesn't have any kickup to the right (an issue which comes up with Dominators from time to time). However, have you noticed that it has a 35/35W bulb, which should be about as bright as a glow worm, so although they may pass IVA, I doubt you'd ever see anything with them!
Nickp
posted on 22/12/16 at 09:46 PM Reply With Quote
I think you'd have to somehow cover the screw etc at the bottom of the lens rim, can't imagine the IVA man been happy with those sharp bits. I'd say no for the IVA tbh
chris_smith
posted on 22/12/16 at 09:56 PM Reply With Quote
I think some sort of nut cover etc would fit or be made to fit those lower screws, it was more the beam pattern that I was as concerned about Iva
But thanks for the input
big-vee-twin
posted on 22/12/16 at 10:56 PM Reply With Quote
Mine failed IVA with 5 inch lamps as the viewing angles were not acheives. I had to change them to 7 inch ones to pass.
You have to be able to see the lamps from low level on the opposite side of the car. Which 5 inch ones the nose cone covers part of the headlamp.
http://www.triangleltd.com
ianhurley20
posted on 23/12/16 at 09:22 AM Reply With Quote
Mine passed with 5 inch lamps - I did spend some time with the manual checking all the look angles for all the lights and everything checked out fine. I guess there may be some differences with some car headlamp mounting points, mine is a Haynes with as book dimensions
CosKev3
posted on 23/12/16 at 09:54 AM Reply With Quote
If you can't meet the sighting angles surely it would be easier to just fit some temporary spacers to lift the light?
Never seen 35w/35 bulbs before,as above if that is correct you won't see much in the dark!
big-vee-twin
posted on 24/12/16 at 10:23 AM Reply With Quote
I thought about spacers, but because my panther has a high bonnet line I decided the 5 inch ones looked out of proportion, I fitted the 7 inch ones and they look much better. They are still on
[img] Screen2
Screen2
[/img]
[Edited on 24/12/16 by big-vee-twin]
