Author: Subject: Citroen C4 engine fault
LBMEFM
posted on 28/3/17 at 02:23 PM Reply With Quote
Just back from a short journey in my wifes C4 Citroen when the engine fault light came on. It displays the fault on the cars read out as "antipollution fault" the engine runs rough and lacks power. Any ideas on what's happened please and how to fix it?
Thanks Barry
mcerd1
posted on 28/3/17 at 02:33 PM Reply With Quote
What engine has it got ?
LBMEFM
posted on 28/3/17 at 02:43 PM Reply With Quote
1600 petrol
posted on 28/3/17 at 03:15 PM Reply With Quote
Originally posted by LBMEFM
1600 petrol
And there was me expecting you to say diesel - in which case I'd say the diesel particulate filter and give it a good pasting to clear it.
ian locostzx9rc2
posted on 28/3/17 at 03:43 PM Reply With Quote
It's got a misfire more than likely could be a lot of things coil pack ,spark plugs injectors wiring ecu and lots more you need to get looked at as it will damage the cat .
wylliezx9r
posted on 28/3/17 at 04:39 PM Reply With Quote
My money's on it being an EGR related fault.
George Best
obfripper
posted on 28/3/17 at 05:04 PM Reply With Quote
Is it an ep6 engine?
If so, check the oil cap and dipstick are seated correctly, they run like a pig if the crankcase system can suck in air, and it may also make the cooling fans run continually.
Dave
r1_pete
posted on 28/3/17 at 05:29 PM Reply With Quote
Daughters did similar a few years ago, it was a stuck vtr valve, another symptom was when starting it sounded as though there was no compression.
We cleaned it and got it running well enough to trade in against a Fiesta.
adithorp
posted on 28/3/17 at 08:04 PM Reply With Quote
Could be any one of hundreds of faults. You need a code read and work from there.... However from experience of how people describe faults and balance of probability I'd pick coil pack.... But I wouldn't bet money on it.
http://jpsc.org.uk/forum/
LBMEFM
posted on 28/3/17 at 08:52 PM Reply With Quote
Thanks for the replies, I'll have a look at it in the morning and let you no how I got on.
posted on 29/3/17 at 07:50 PM Reply With Quote
A code reader should take some of the guests work out. Failing that drive away from home and call the AA man out, he will tell ya... presuming you have break down cover...
