Author: Subject: Best oil grade for an older modern car
Mr Whippy
posted on 26/4/17 at 11:04 AM Reply With Quote
I have my camo Volvo petrol 2.0 turbo and the manual states 5W/30 oil but the car has done almost 100k probably hard miles and I’m now thinking this watery oil is fine when new but really a bit thin for the car now, apart from going to a 5W/40 oil is there a better grade or solution for high mileage cars. I recently changed the oil with 5W/30 but the engine now seems nosier especially tappet noise which is now noticeable.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
posted on 26/4/17 at 11:27 AM Reply With Quote
Stick with 5w/30 full syth unless it galloping through oil.
Mr Whippy
posted on 26/4/17 at 11:31 AM Reply With Quote
doesn't burn any oil and the emissions are clean for the MOT, just after changing the plugs and they were spotless so generally I think the engine is in good health, just the last oil change seemed a little bit nosier...
posted on 26/4/17 at 12:21 PM Reply With Quote
I'd stick with the OEM oil recommendation. 100k is not that higher mileage and as above unless it's using a lot of oil the OEM spec should be best.
Mr Whippy
posted on 3/7/17 at 06:20 AM Reply With Quote
Well just and update on this...
I had 5w/30 fully synthetic in but decided this was not acceptable as the noise from what seems to be the cam gear is far to loud, especially as I have another recently purchased identical S60 which doesn't make any noise (not sure what grade its on).
So still going on the hand book for the time of year changed to a 20w/40 part synthetic and all the noise has vanished! it now runs a silently as it should.
From this even though both oils are fully to the manufactures spec the protection of such thin oils I'd have to say is questionable and will be steering clear of these grades from now on.
Angel Acevedo
posted on 4/7/17 at 12:04 AM Reply With Quote
I live in the tropics, but have tried to keep using recommended oil.
Notwithstanding, last two oil changes I haven´t found 5W30 and used 10W40 if my memory serves me OK.
I may as well stick to the new spec as easier to find and additional peace of mind as we don´t have such low temperatures in the morning, therefore such low viscosity is not needed at startup.
You may need to go back to 5W30 in winter.
Hope my post makes sense.
Slimy38
posted on 4/7/17 at 07:00 AM Reply With Quote
Personally I wouldn't have gone for a part synthetic oil of any grade in a turbo car, but I only have internet based gossip to back that up.
v8kid
posted on 4/7/17 at 10:39 AM Reply With Quote
Ditto - I even use fully synthetic in my van
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   v8kid 's Aim
