Author: Subject: CV Joint Rebuild
Ron86
posted on 11/9/17 at 08:08 PM Reply With Quote
CV Joint Rebuild
So, in the process of stripping my Zero for a full rebuild, I've just made a bit of a newbie error. Taking the driveshafts out (Lobro type) I dropped one of them and the CV joint literally fell to pieces -balls and all!
The sierra manual explains how to overhaul them but nothing about literally rebuilding them and I can't seem to get the balls back in place and the joint back together. Does anyone have any tips or tricks? Might be because I'm trying to do it with all the grease stil in place lol! Slippy as 'eck!
[Edited on 11/9/17 by Ron86]
loggyboy
posted on 11/9/17 at 08:36 PM Reply With Quote
Buy a new one. They are only 13.
IIRC unless you get the right balls in the right hole the tolerances will cause premature wear/failure.
posted on 11/9/17 at 08:38 PM Reply With Quote
Clean all of the grease from all of the parts before reassembly , then it's a case of fitting the parts togetherworth putting your location in your profile as someone local may be able to help if you have problems. without the balls and swivelling the inner sections to replace the balls one at a time before repackaged with fresh grease. Might be
mcerd1
posted on 12/9/17 at 09:14 AM Reply With Quote
Been there done that - the good news is that its fiddly, but not impossible
this video gives you the idea:
40inches
posted on 12/9/17 at 09:47 AM Reply With Quote
As loggyboy said, for 13, why bother?
mcerd1
posted on 12/9/17 at 07:15 PM Reply With Quote
It's still 13 vs 0
Besides its quite satisfying when it all clicks back in
40inches
posted on 13/9/17 at 07:32 AM Reply With Quote
Originally posted by mcerd1
It's still 13 vs 0
It's not that you're tight then?
