<<  1    2  >>
Author: Subject: Turbo an old Landy
Mr Whippy
posted on 12/3/18 at 01:18 PM Reply With Quote
Turbo an old Landy
Rather than risk posting this on a Landrover site which usually gets the same old boring put a hellishly noisy TDi engine bla bla yawn.... in it as if I even like diesels one bit or I want even more noise in an already noisy enough truck thank you very much or want clouds black smoke pouring out of it too (get the picture...not interested in a diesel btw )
I'm sticking with the nice pleasant very quiet petrol engine however its a bit low powered for various reasons and could do with an extra 20bhp which would get it at reasonable levels for hills and head winds
The petrol engine was the basis of the diesel engine and mines a 5 bearing one so I have no issues on it's strength and I don't want it to rev any faster than normal either as the rods are stock. All the performance improvements you can get are basically trying to get more flow through the engine and big bonus can be gained (45bhp or so) but at big costs.
As I have a lot of room in the bay and the down pipe is a 1/2m straight pipe I was thinking why not just fit a small turbo? I think the compression is 7:1, it has a carb which I think (I'll have to check) could be pressurised without float chamber issues. There's even room behind the grill for an intercooler too.
Was thinking of just putting it together from scrap car parts (one locally) and a downpipe is like a tenner. Engine is a 2.25ltr but as it doesn't turn very fast probably is equivalent to a 1.8ltr modern engine for flow, if that certainly the carb is small. Any suggestions for a suitable donor? would be wanting quite a low boost, like I say 20bhp would be fab. What do you think would be a sensible boost amount?
Any idea's would be appreciated
[Edited on 12/3/18 by Mr Whippy]
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
coyoteboy
posted on 12/3/18 at 01:26 PM Reply With Quote
Pop a T4 from a PSA engine onto it and push actuator pressure in there in there? Should spool nice and fast and not be pushed particularly hard.
Report your local potholes, it actually works!
MikeR
posted on 12/3/18 at 01:29 PM Reply With Quote
Have you considered getting a mini supercharger?
You'd then have the power boost all the time.
Mr Whippy
posted on 12/3/18 at 01:39 PM Reply With Quote
cheers, I'll look into that
Mr Whippy
posted on 12/3/18 at 01:41 PM Reply With Quote
hmm sounds more expensive than a turbo and more difficult to drive (the power steering pump was a pain enough to fit) it's all low torque v-belts on that thing
posted on 12/3/18 at 01:59 PM Reply With Quote
Don't really know Landys much at all so I'm curious, I'm assuming it's an inline 4 cylinder engine you have in there?
If so (again curious) what sort of cost and complexity is involved in fitting a V8 engine?
A chap who worked where my wife does has a V8 Landy and I have to say it does sound superb just burbling along. He doesn't do many miles in it, but does tow contract gardening kit around so likes the towing ooomph it gives him.
ss1turbo
posted on 12/3/18 at 02:31 PM Reply With Quote
I'd look not necessarily at the engine size, rather the expected bhp. IIRC a 2.25 petrol will be harbouring a tiny downdraught Solex? If so, the ideal solution would probably be the 32DIS off a Renault 5 turbo (115bhp from memory?), which is ready to go for forced induction. You'll need something to wind back the ignition when on boost; not much for a clockwork distributor although a vac advance unit from an early Saab turbo IIRC might fit with some fiddling. You used to be able to get a simplistic box-of-tricks (Turbo Dynamics?) that retarted the ignition by x degrees per 1000rpm which should save pre-ignition.
Turbo size...probably without getting technical, then something, again, similar bhp rated if petrol, which normally means a T2 or one of the smaller spec T3s. You might get away with a PSA TD one which are probably cheaper and easier to find although the characteristics are somewhat different (and petrol turbos run a higher temp than diesels).
Long live RWD...
dinosaurjuice
posted on 12/3/18 at 03:06 PM Reply With Quote
turbo sounds like a great project but my gut feeling says a rover V8 would be easier and give a better end result. just my 2p...
posted on 12/3/18 at 03:32 PM Reply With Quote
I guess that was my thinking as well.
Not being familiar with them though I've no idea if that would entail chassis + fuel system mods etc. to get it to work. I have a feeling Whippy's after minimal mods and keeping it relatively cheap and quick to do.
blue2cv
posted on 12/3/18 at 04:07 PM Reply With Quote
Suck thro carb using an SU, no worrying about pressurising carb body
ss1turbo
posted on 12/3/18 at 04:18 PM Reply With Quote
As long as the turbo can do this (not all can from memory - needs to have the right seals?) - plus you can't run an intercooler.
Long live RWD...
blue2cv
posted on 12/3/18 at 04:24 PM Reply With Quote
Surely intercooler fitted between turbo and engine, so fuel input method unimportant
coyoteboy
posted on 12/3/18 at 04:41 PM Reply With Quote
If you're sucking through the carb you would be fueling into the IC. You'd get fuel condensation and pooling in the IC.
mark chandler
posted on 12/3/18 at 10:23 PM Reply With Quote
RV8 will give you the power and economy over that agricultural 2 1/4 four pot, I used to race a standard series 2a, skimmed head, had Kent cams regrind the base circle to 285 degrees and it was still rubbish, just a bit faster.
Turbo would be interesting, just keep it simple with a front ended SU
ss1turbo
posted on 13/3/18 at 11:49 AM Reply With Quote
As you can get an SU adaptor for the 2.25, fit that, with the SU from a Metro Turbo (as it's got no electronics like the Montego one)? Will need re-needling but the Montego one will probably be close..
Long live RWD...
DavidW
posted on 13/3/18 at 12:06 PM Reply With Quote
I had the 2.5L petrol in my Defender and replaced it with a 3.9 v8 on megasquirt when I rebuilt it.
MPG isn't that different, although the work and parts needed were not insignificant. The v8 makes it go rather well and the noise it makes it much nicer.
The Subaru TD04 (?) turbos seem popular on the internet for sticking in places where they wouldn't normally be although would be more work than the other suggestions here.
If you're only going for a little extra power, the rest of the drivetrain will be fine providing its all maintained.
posted on 13/3/18 at 06:34 PM Reply With Quote
I have rover v8 in my lightweight, never got over 15 mpg on a motorway run at 60-70mph.
You will need adapter plate to mate to the gearbox and RR diffs. And then upgrade front brakes.
In the lwt, the bulkhead needs hacking as the v8 with low profile manifolds is a very tight squeeze, a panel in the tunnel is needed to access the last spark plug. These mods may not be applicable to the civilian models.
A cheaper option may be to increase cr, port the head, fit decent flowing inlet and exhaust manifolds and better carb(s).
Don't forget the engine is throwback to the 50s and is intended to run on low grade petrol so is not tuned for performance.
Visit China. Meet the child that made your trainers.
posted on 14/3/18 at 11:20 AM Reply With Quote
I understand you're not a diesel fan for this application, but is there not a VW/Audi TDI that would fit. Admittedly I'm not able to drive on the road for the time being, but I've driven VAG TDI's for many years (SWMBO has and still does too).
Granted modern tin tops are more sound proofed than your Landy will be, but for everyday driving VAG TDI's do it for me. Enough power, plenty of torque, reliable and economical.
I'm sure such a conversion would entail fuel system changes, maybe even the fuel tank itself. Once done the power and torque on offer would surely make it worthwhile though (?)
[Edited on 14/3/18 by nick205]
Mr Whippy
posted on 14/3/18 at 01:01 PM Reply With Quote
na been there with the diesels, utterly hate them, not even a consideration. If I'd wanted a TDI or v8 Landy I'd have just bought one originally rather than convert this one.
V8's out, too many things to change (gearbox, brakes, bulkhead, exhaust, props etc etc) and even with LPG is still a guzzler
Some very helpful stuff on suitable turbo's and I was looking at an 1 3/4 SU conversion as that flows much better and is quite a simple and cheap mod, plus it works well with running boost, there's an article on how to convert standard ones to turbo which doesn't take much. Going to pick up a second hand SU and refurbish it. I've already ported the head and matched the inlet (was miles out, terrible mismatch), slightly more power from that but not enough.
It will be a very basic installation as I said only looking for a 20hp gain and even swapping to the SU and the 2.5 cam will give almost half that
Thanks for all the info
[Edited on 14/3/18 by Mr Whippy]
posted on 14/3/18 at 03:01 PM Reply With Quote
Point taken on the diesel and V8 - I'm not too different in my own opinion of better to buy the original OEM one if that's what you're really looking for.
Presumably your camo Volvo is your daily driver and the Landy's more of a weekend/toy vehicle?
posted on 14/3/18 at 03:31 PM Reply With Quote
Fitting an SU and increasing the CR to ~9:1 will probably get you close to the power you want, coupled with better economy. Some optimisation of the ignition advance curve will be needed, but that would be the case for turbocharging it anyway.
Could always go for a Megajolt or similar and do away with the clockwork ignition altogether.
[Edited on 14/3/18 by MikeRJ]
Mr Whippy
posted on 14/3/18 at 09:51 PM Reply With Quote
Its got electronic ignition which is very good but doesn't allow any curve adjustment adjustment. Not sure about increasing the compression above 8:1 they seem to suffer from detonation and there's no anti knock sensors.
Mr Whippy
posted on 14/3/18 at 09:56 PM Reply With Quote
Na the landy (Percy) is used everday and volvo is just used when I need more seats...its 95% a city truck tbh not recommended unless you are nuts
DW100
posted on 14/3/18 at 10:17 PM Reply With Quote
What about a nice Volvo 5 cylinder conversion?
ReMan
posted on 14/3/18 at 10:48 PM Reply With Quote
I like your idea of a nice simple add on
The engine sounds fine for it so get on and do it
www.plusnine.co.uk
∙،. ˘≈ﺣ
View User's Profile Visit User's Homepage View All Posts By User U2U Member   ReMan 's ICQ status
<<  1    2  >>
