Author: Subject: Sierra Steering Column Switches Wiring
jamiepearson69
posted on 18/2/19 at 03:57 PM Reply With Quote
All
I know its probably been covered before, but I can't find anything in the search engine.
I want to remove the column switches, which are standard sierra and relocate these to the dash with custom switches.
What is the best way of doing this? I recall a plug and play loom being available, but can't for the life of me remember who made it.
A long time ago (pre internet) I tried to do this to another project and could not work out how the switches work. Is there a wiring diagram?
James
posted on 18/2/19 at 04:43 PM Reply With Quote
Don't know if this is any use to you. I used it when wiring up my donor Sierra stalks to a Vicky Green wiring loom in my MK Indy.
Smoking Frog
posted on 18/2/19 at 08:01 PM Reply With Quote
Not what your asking for as I kept the left stalk and moved light switches to dashboard. May help?
Left Stalk Relays
Left Stalk Relays
johnhsmith
posted on 18/2/19 at 11:03 PM Reply With Quote
Try www.premierwiring.co.uk. I used a loom from them that was Sierra based but basic. All info with it plus quite helpful with problems.
ianhurley20
posted on 19/2/19 at 12:15 PM Reply With Quote
Whilst we are on this subject does anyone have anything that gives you the pin functions on the stalks. I have the stalks but no wiring attached and am going to try and wire them up. It would save a lot of trial and error!
Nick - just found the photo you probably posted above (that will not display for me) in your archive whih probably answes my question above - thanks
[Edited on 19/2/19 by ianhurley20]
My build blog http://ianhaynes20.wordpress.com IVA passed 3/10/16
written off 23/9/18
Aug 2019 completed Tiger Avon with ST170 on TB's
Now restoring 1968 Ginetta G4
posted on 19/2/19 at 12:35 PM Reply With Quote
There has been several post covering Sierra switch wiring on the forum , donít know if the posts have been lost due to photo storage problems?
you.
Two minutes using the search facility shows up loads of posts on the subject.
[Edited on 19/2/19 by rusty nuts]
johnhsmith
posted on 19/2/19 at 12:44 PM Reply With Quote
Ian,
I have a word document from premier with lots of info on the switches including the pin numbers. Let me have your email and I can send them to you
John
ianhurley20
posted on 19/2/19 at 01:07 PM Reply With Quote
PM sent, thanks John
written off 23/9/18
ianhurley20
posted on 19/2/19 at 03:47 PM Reply With Quote
you.
Thanks rusty nuts - I think I have plenty of info now
written off 23/9/18
posted on 19/2/19 at 05:43 PM Reply With Quote
One day I will work out how to put a link in my posts.
