<<  1    2  >>
Author: Subject: Expanding Foam Seats, any pics?
Humbug
posted on 30/3/05 at 07:44 AM Reply With Quote
My 2 penn'orth: on my ST the floor is steel, not ali. I know because a) it was hard to drill through and b) I checked with a magnet.
Because of the ST harness mount height problem I was planning to bolt the seats directly to the floor with some honking great washers I saw in Wickes at the weekend - they must be 2" diameter.
Anyone any thoughts on this with a steel floor, or should I still be looking at some bracing/spreader plates?
NS Dev
posted on 30/3/05 at 12:21 PM Reply With Quote
With a steel floor, I'd be happy with that. Certainly Ian gray said that's what most people do as far as he knows.
My car has the race thin lightweight alloy floor, I riveted it in!
MikeR
posted on 30/3/05 at 12:31 PM Reply With Quote
in my mind the seat doesn't take a lot of force - the seat belts should be holding you in so that should cover it nicely.
NS Dev
posted on 31/3/05 at 07:52 AM Reply With Quote
Yup, my thoughts as well.
RazMan
posted on 31/3/05 at 06:19 PM Reply With Quote
The harness only really keeps braking / frontal collision forces under control Sideways and rear collision forces might be an issue though - best to secure it like your life depends on it ....... it might
Raz
MikeR
posted on 31/3/05 at 07:37 PM Reply With Quote
Errm, surely with a rear collision you're going to be pushed back into the seat..... even the smallest bolt is going to hold it in place as its being pushed onto its self - yet has the force spread about the whole seat area.
I'm not sure about cornering as i'd expect a lot of the force to be taken by your seat belt (i'm assuming a min of 4 point here).
Perhaps I'm just wrong.
(that last line isn't supposed to sound like that, i'm just trying to say i've not finished mine so i could be completely wrong & yes mine will be hard against the bulk head)
[Edited on 31/3/05 by MikeR]
RazMan
posted on 31/3/05 at 09:51 PM Reply With Quote
Ah ... I was thinking about my own setup - my seat is forward of the rear bulkhead by about 200mm so is totally dependent on the floor mountings. I believe your seat is probably mounted hard against the bulkhead so you are indeed right.
Raz
irvined
posted on 6/4/05 at 09:50 AM Reply With Quote
Hello,
Heres some pics of mine:
http://www.irvined.co.uk/gallery/Arches/cimg0232
http://www.irvined.co.uk/gallery/Arches/cimg0238
It needs some trimming and covering. But its nice and comfortable - I'll probably make another which has me sitting lower down and further back, but its a good start.
HTH
<<  1    2  >>
