<<  1    2    3  >>
Author: Subject: Paddle shift kits
the_fbi
posted on 24/3/06 at 06:29 PM Reply With Quote
I don't suppose you'll be able to do one which accepts the allegro column?
Either way, it'll look great on the wall even if I can't get it to fit, so I'll take one too
Feel free to email me to chase in case I miss this thread. chris@chrismobile.com
ta
Chris
highspeeddirt
posted on 24/3/06 at 08:04 PM Reply With Quote
Put me down for one too
[Edited on 24/3/06 by highspeeddirt]
the moa 2
posted on 24/3/06 at 09:03 PM Reply With Quote
Me too please.
Any idea on when you think you'll start em ?
mad-butcher
posted on 25/3/06 at 09:48 AM Reply With Quote
this place do an aluminium anodising kit and a nickel plating kit ...Frost Restorers Equipment www.frost.co.uk
pathfinder
posted on 27/3/06 at 06:29 PM Reply With Quote
Evening all,
I have placed an order for the first batch of laser cutting and expect to have a finished product ready for dispatch in 2-3 weeks time! I will keep this thread open and offer the first kits to those who expressed there interest first!
I didn’t expect to get such a good response so it looks like I have a few long nights in the workshop coming up!
Keep checking this thread for progress
Regards
Thom
the moa 2
posted on 27/3/06 at 09:37 PM Reply With Quote
COOL !
whpracer
posted on 28/3/06 at 07:32 PM Reply With Quote
I also would like to order one if you don't mind sending it to holland ?
or maybe I can pick one up at stoneleigh ?
cheers
pathfinder
posted on 6/4/06 at 09:58 PM Reply With Quote
Just a quick update on the paddles
The first batch of parts have been made/ordered I’m just waiting for the laser cutting to be delivered (hopefully tomorrow, defiantly early next week?!?), then it’s a couple of hours welding and 2-3 days for powder coating (and anodizing if any1 wants it) I can see the bank holiday messing up all my plans though???
Will post a few shots of the laser cutting when it arrives!
Regards
Thom
Whpracer:
Holland is no problem.
the_fbi
posted on 6/4/06 at 10:18 PM Reply With Quote
Winston Todge
posted on 6/4/06 at 10:42 PM Reply With Quote
Looks like a great bit of engineering Thom! You do stuff like this for your work?
I am very interested in this design but am also retaining the Sierra switchgear. Would the version two be able to fit in front of the switch gear? What are your ideas on mounting points?
Thanks mate and very interested to see what the version ones look like!
Ta,
Chris.
tks
posted on 7/4/06 at 05:23 AM Reply With Quote
mhhhi Think
that the problem with the sierra with switches will be that the switches should stay accesible. This sounds logic but the alu moon shape will be hiding them.
Also the room between the switches and the wheel isn´t much. Sow the movement cant be much to.
The trick should be that the ring is mounted behind the switches, and that the press plate is mounted before the switches.
the only option i see is to make the ring smaller to not to hide the switches, but have no idea if anyone can still reach the ring then.
also we should test if the HIGH beam switch is a problem because of its direction of movement.
Regards,
Tks
[Edited on 7/4/06 by tks]
pathfinder
posted on 7/4/06 at 09:04 AM Reply With Quote
I’ve got a degree in industrial design but have a boring day job so am doing little projects like this to keep my hand in! I haven’t had time to look at the mk2 version in much detail but as tks says it’s a bit of a squeeze to get all the controls in the correct place but I’m convinced it is possible.
locoboy
posted on 9/4/06 at 04:24 PM Reply With Quote
Will this design allow you to retain the 'collapsable' section of the column required for SVA purposes?
Locoboy
gttman
posted on 9/4/06 at 07:39 PM Reply With Quote
I'm also interested, is there a st'd way of connecting this to the gearbox?
pathfinder
posted on 10/4/06 at 08:21 PM Reply With Quote
Hi gents,
I got the first batch of laser cutting back today so couldn’t resist building one up to show you! It’s in its raw state and will look even better when powder coated and anodized! Price for Black powder coated stem and raw aluminium is going to be £68 collected or £73 delivered. Anodizing will be extra and I should have a price for this tomorrow!
Locoboy- this design does not use the collapsable section so may not be sva friendly!
Gttman – the paddle shifter connects to your gearbox via rods & levers, have a look through the photo archives for inspiration, every build is slightly different so I can’t offer a complete kit, although there are a few more parts in the pipe line…
[Edited on 10/4/06 by pathfinder] Rescued attachment proto 003.jpg
Pezza
posted on 10/4/06 at 08:45 PM Reply With Quote
looks delish mate, still defo after one
Just let me know when I reach the head of the list and i'll send you the money.
Pez
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
gttman
posted on 10/4/06 at 10:12 PM Reply With Quote
OK so they are retrofit.... I'm still keen, would there be any chance of getting a pair without the bolt holes so that I could get them alloy welded instead?
zxrlocost
how thick is the alloy mate
mandbsheldon
posted on 11/4/06 at 04:58 AM Reply With Quote
Just let me know when they are available!!!!!!!!
And how/when you want your money, no problem if you want it in advance.
Leigh.
carlgeldard
posted on 11/4/06 at 06:51 AM Reply With Quote
I like it. Where are you and how would you like the payments to be made.
Carl
pathfinder
posted on 11/4/06 at 09:39 PM Reply With Quote
Evening all,
I spoke to the anodizing man and he can alchrome (gold) the + & - paddles and etch the other ali parts so they are silky smooth for the princely sum of £7! He did a sample for me while I was there and it looks quality!
Answers to the above questions:
Gttman:
At the moment I can only get them with the holes pre cut, any welder worth his salt should be able to fill the holes for you and then polish it up!
Zxrlocost:
The ali is 4mm thick but doubled up to 8mm at the adjustable sections, zero flex!
Mandbsheldon & Carl
I live in a small village near Huntingdon (cambs) if anyone wants to come collect a kit!
Paypal is my preferred method of payment/donation but can except cash or cheque!
The bank holiday is going to hold up production a bit but I shall have a few shots of it in the car by the end of the weekend and finished kits by late next week!
Shall keep you all posted
Regards
Thom
zxrlocost
posted on 12/4/06 at 08:48 AM Reply With Quote
alright mate I appreciate its doubled up
but I really would try one first
if you have or your certain then fair enough
whpracer
posted on 22/4/06 at 12:32 PM Reply With Quote
Hi Thom,
how is it going with the paddle shift kits ?
any idey when you have them ready ?
I would like to have the paddle's finished in that gold look.
paypal payment is good, and do you have any idea about delivery cost to holland ?
cheers
peter
the moa 2
posted on 26/4/06 at 07:46 PM Reply With Quote
Dont supose any paddles will be ready for the stoneleigh show if ya going ?
I can pay when ever you need.
carlgeldard
posted on 27/4/06 at 06:54 AM Reply With Quote
Same here
Thanks Carl
<<  1    2    3  >>
