Author: Subject: Instrument Gauge Surrounds?
Gareth
posted on 12/6/07 at 07:46 AM Reply With Quote
After a slip while cutting the gauge holes in my dash board, I need to make or buy four surrounds to sit between the dash and the gauge to tidy things up and give a good finish.
I was thinking of some kind of metal washer, shim or a rubber washer with a 52mm internal diameter, and between 65mm to 67mm outside diameter.
Any one got any helpful ideas?
Gareth
Moorron
posted on 12/6/07 at 07:53 AM Reply With Quote
i thought about this when i redid my dash, if i slipped or just drilled unlevel it would look poop. I thought about getting some laser cut 1.6mm stainless steel rings about 5 mm diameter bigger than the dials. Didnt bother in the end.
But if there is alot of interest i can get some made.
unless somewhere else here can link to something simular.
Gareth
posted on 12/6/07 at 07:59 AM Reply With Quote
Cheers for the reply.
I don't want to redo the dash for a tiny bit of damage but also want it to look right.
I was hoping to try and find something off the shelf, as if you don't know some one it could get very costly.
Gareth
Humbug
posted on 12/6/07 at 08:02 AM Reply With Quote
As an alternative to the ring suggestion, could you make a sort of backplate behind 2 or more dials? Rescued attachment dash dials.jpg
Johnmor
posted on 12/6/07 at 08:12 AM Reply With Quote
Alu
I used a bit of aluminium and cut all the dial nto it, looks ok.
You could polish to almost chrome if you had the patience.
ayoungman
posted on 12/6/07 at 10:06 AM Reply With Quote
why not use some abs sheet with Carbon fibre effect. easy to cut and finish. Won't break the bank either.
"just like that !"
edspurrier
posted on 12/6/07 at 01:26 PM Reply With Quote
Does that fit with the SVA "soft dashboard" radiu edge? If so I've got some nice turned aluminium I might use myself
Ed
Gareth
posted on 13/6/07 at 08:19 AM Reply With Quote
Cheers for the replies, defiantly some food for thought.
Gareth
omega 24 v6
posted on 13/6/07 at 11:43 AM Reply With Quote
What's the dash made of?? can it be removed from the car and set on a bench drill?? if it's ally or stainless youcould try the old wooden dowel in the chuck with lapping paste and create a finish like thisNice finish
