Author: Subject: Options for trimming floor?
rayward
posted on 25/4/08 at 10:20 AM Reply With Quote
i want to get rid of the carpet from the floor on my indy, thought about checker plate, but seems a bit "industrial" any other options? any pics of what you;ve done?.
cheers
Ray
madmandegge
posted on 25/4/08 at 10:33 AM Reply With Quote
I'm interested in any idea's too, to be honest I'm tending towards treating the floor with rust remover, then seeing what simple black hammerite looks like.
When I bough it, the car already had checker plate in the drivers footwell, looks OK, but am thinking of maybe a non-slip rubber mat cut to shape instead?
worX
posted on 25/4/08 at 10:40 AM Reply With Quote
Rubber, trimmed to size...
rubber floor and new tran tunn
Humbug
posted on 25/4/08 at 10:46 AM Reply With Quote
I used ali chequer plate on top of the steel floor, but I did think of using that industrial rubber matting with raised circles on it if you know what I mean:
speedyxjs
posted on 25/4/08 at 11:34 AM Reply With Quote
I like locor1's floor
posted on 25/4/08 at 11:38 AM Reply With Quote
I've got rubber flooring that has little raised diamond shapes on it. I wanted the industrial look!
In reality I wanted flooring that wouldn't get spoiled if it got wet (no roof, no windscreen). In the same way, I've got GRP seats with vinyl pads.
Oh - it also stops the welded steel floor 'bonging' every time I climb in.
[Edited on 25/4/08 by David Jenkins]
alfasudsprint
posted on 25/4/08 at 12:01 PM Reply With Quote
what's locor1's material then???
whats a cheap source of ali chequer plate guys? laast time I looked it was bloody expensive.
les g
posted on 25/4/08 at 01:19 PM Reply With Quote
flooring
this might sound daft at first but !!!!!
what about that textured lino stuff from carpet shops they do all sorts of textures immitation chequer plate industrial effects
diamonds and ripple weaves etc and it would be simple to cut and fit and waterproof
what do think
les g
madmandegge
posted on 25/4/08 at 01:21 PM Reply With Quote
locor1's is carbon effect I think? looks very smart!
Steve, the rubber mats also look quite smart, can I ask where you got the rubber? I'd need to get some cutting practice in before I attempted it, but seems ideal for what I want!
worX
posted on 25/4/08 at 01:27 PM Reply With Quote
I have a CoachTrimmers in the next town so i bought some off them.
They do have a webshite though, and they do deliver.
They were also at Stoneleigh last year so I assume they might be there this year too?
http://www.martrim.co.uk
HTH
locoR1
posted on 25/4/08 at 03:07 PM Reply With Quote
Just found this thread, Somebody stole a picture of my car
I got my floor from "Here" its 1.5mm aluminium 3 bar (cricket weave) down at the bottom of the page on the link,
I've used it over a steal floor so didn't want Checker plate to thick and heavy, the guy i spoke to couldn't of been more helpful, all cut to size and delivered for £40
Although I'm starting to have withdrawal symptoms with the lose of my lovely carpet
Check out my CB500T Cafe Racer build diary
alfasudsprint
posted on 25/4/08 at 04:04 PM Reply With Quote
locor1-nice floor.
what size s/wheel is that?
Tim
posted on 25/4/08 at 06:01 PM Reply With Quote
After the powder coating on my floor lifting I painted it with rustproofing paint and when it was dry I stuck on some self adhesive anti slip .Does what it says , now my feet don't slide about and going to do the passengers side as well . Stuff I used was left over from a wheel chair ramp but is similar to skateboard decking.
triumphdave
posted on 25/4/08 at 07:07 PM Reply With Quote
I have ribbed rubber on my floor,bought it from Camping and general (caravan step rubber)
locoR1
posted on 25/4/08 at 07:45 PM Reply With Quote
Originally posted by alfasudsprint
locor1-nice floor.
Tim
Its 260mm a bit to small,
when i find a nice flat bottom 280mm for the right price its going!
adithorp
posted on 26/4/08 at 06:12 PM Reply With Quote
I used industiral floor covering stuff. The kind of none slip Lino type stuff that they stick down in hotel kitchens etc. Done in lots of colours and lighter than lino, rubber and ally checker.
adrian
dnmalc
posted on 28/4/08 at 09:44 PM Reply With Quote
Stainless and it even stiffens up the chasis
foes
posted on 28/4/08 at 10:17 PM Reply With Quote
After seeing how good locoR1's floor looks i decided to order some from metalsdirectuk, but they've just bout ran out, only got small pieces left and they can't get any more, extremely helpful chap tho...
asl
posted on 29/5/08 at 03:44 PM Reply With Quote
I'm doing my best sheep impression as well! LocoR1 floor looks amazing so I also called metalsdirect.
Completely stupid question now but..... They asked for measurements. did you send a template or just measurements? don't suppose you still have the measurements that I can steal from you?
i am very new to this locost thing, didn't build just bought my MK indyblade ready made. i'm starting to tinker but having to start with the very basics.
Many thanks
locoR1
posted on 29/5/08 at 05:35 PM Reply With Quote
Hi, I just had them cut to size as rectangles then cut the angles for the front two with a jig saw.
Didn't keep the measurements but they wouldn't be any good to you anyway the tunnel on an indy is different especially at the front.
Dave....
asl
posted on 30/5/08 at 04:03 PM Reply With Quote
Perfect, many thanks locoR1 I will do the same. thanks again Nathan
C10CoryM
posted on 31/5/08 at 01:50 AM Reply With Quote
I was thinking of using a thick kevlar weave with trimmed edges (no epoxy). Id go for carbon but its pretty abrasive and I dont think it hold up to constant rubbing well either. Anyone know for sure?
"Our watchword evermore shall be: The Maple Leaf Forever!"
