<<  1    2  >>
Author: Subject: Track Vs Wheelbase?
mark chandler
posted on 1/7/08 at 07:28 PM Reply With Quote
My recollection is 1:1.61.
In my experience handling will really suffer under hard braking, expect the rear to try and come around.
Regards Mark
iank
posted on 1/7/08 at 07:44 PM Reply With Quote
Originally posted by garage19
Originally posted by chris mason
yep mine's a similar length with a wb of 1890mm but my track is only 1175mm
that gives me a ratio of approx 1.6ish
yours sounds a little square almost kart like, btw don't be put off by having to have custom driveshafts made, a pair will cost well under £200 so there's no reason to compromise the project.
Chris
That is much cheaper than i thought. Any links to suppliers?
GB Engineering £80 each for road ones, £160 each for 'unbreakable' gun drilled competition ones.
http://www.berrisford.co.uk/product_info.php?cPath=45&products_id=67&osCsid=jkmf56q1ju2qfe72fv2jaa58g6
Anonymous
Syd Bridge
posted on 2/7/08 at 08:39 AM Reply With Quote
Oddly enough, the ideal ratio seems to be that 'human ratio' thing, which is 1:1.6+.
Someone mentioned LMP cars. You can't use the obvious figures for these, because they are designed to maximum body widths, and also the wide tyres make things a little different to the accepted norms.
Syd.
[Edited on 2/7/08 by Syd Bridge]
<<  1    2  >>
