<<  1    2  >>
Author: Subject: VW / Audi Gearbox Linkages
mr henderson
posted on 13/8/08 at 08:38 PM Reply With Quote
Well, I'll be interested to see pics of both finished versions eventually, but I must say, that, in my own personal opinion only, that they seem like a lot of work and materials compared to the cable option.
John
posted on 13/8/08 at 08:52 PM Reply With Quote
The 'cockpit rod' will simply be a straight rod held at both ends by a rose joint, so that it can slide back and forth, and side to side.
Towards the front of this 'cockpit rod' (about 20cm back) there will be a shorter rod welded at a right angle and pointing up. This will be the gearstick.
The 'intermediate rod' is connected to the 'cockpit rod' and 'gearbox rod' with steering couplings and is also held at both ends by rose joints attached to lower chassis rails.
Finally, the 'gearbox rod' (with ball joint at mid point) is held at both ends by rose joints attached to upper chassis rails.
Because all fronts / ends of rod sections are hard fastened in place, the movement at the gear stick will be replicated throughout.
If you look at this picture of a Spyker gearstick, it will give you some idea (but delete the lower rod as I won't be using one).
I too had thought about cables, but I have most of the component parts at hand for the rod assembly, so I'm going that route. I couldn't figure how to control the cables at the gearstick end.
mr henderson
posted on 14/8/08 at 06:53 AM Reply With Quote
So presumably the gearbox/engine assembly will be rigidly, or at least extremely stiffly mounted to the chassis? (in order to prevent unwanted selector movement during acceleration and braking)
Jon
posted on 14/8/08 at 09:28 AM Reply With Quote
Yep... my mounts will be somewhat agricultural in design!
<<  1    2  >>
