Author: Subject: rear lights
jabbahutt
posted on 24/9/08 at 01:30 PM Reply With Quote
rear lights
Well I'm getting a bit better at posting these photos so here is a view of the rear lights.
I'm really happy with how they turned out. If anyone is considering the Hella led ring lights I have a really cheap easy solution as fitted in the photo.
Anyone care to guess what the housings are made of?
[img] rear lights
rear lights
[/img]
davidinhull
posted on 24/9/08 at 01:35 PM Reply With Quote
OK - no idea
a4gom
posted on 24/9/08 at 01:36 PM Reply With Quote
drain pipe?
Perfect planning prevents pi$$ poor performance!
jabbahutt
posted on 24/9/08 at 01:39 PM Reply With Quote
pretty damn close. They're made from the plastic union for kitchen extract ductwork.
bought 5 from Wickes for about 80p each and cut in half at the thicker bit where the ducts meet.
Bit of wet and dry to clean the face and spray black.
The Heela Rings are a nice tight push fit and you can make them thicker or thinner to suit the rear wings on your car.
Hope it helps someone
Benzine
posted on 24/9/08 at 01:45 PM Reply With Quote
Nice Get them from SVC? I'm about to order some rear lights myself. When I had the same type on my MK i used some drain pipe from B&Q but on my Elan shell I won't need to extrude them and I can have them flush.
Bluemoon
posted on 24/9/08 at 02:09 PM Reply With Quote
Car's looking good.. Congrats..
Dan
Kriss
posted on 24/9/08 at 02:38 PM Reply With Quote
Look great.
Would Hello lights fit into the SVC circle CF effect housings like mine have (See archive)
I imagine the lights are similar sizes/diameters
jabbahutt
posted on 24/9/08 at 02:47 PM Reply With Quote
I started out with the carbon effect ones from SVC. The problem is you need to cut the two screw attachment off to fit the Hella lights and because they are tapered on the back edge I found a large portion of the light stuck through the rear wing and I wasn't happy with the fit.
People have used the SVA mounts successfully with the Hella lights but I couldn't find any decent photos of them fitted from inside the wing to convince me how they attached.
A search on here should bring up some threads on the subject.
Nigel
Delinquent
posted on 24/9/08 at 03:10 PM Reply With Quote
that's a cracking job you've done on the dash board - looks very professional.
Kriss
posted on 24/9/08 at 03:33 PM Reply With Quote
where can I pick up some hellas?
posted on 24/9/08 at 05:50 PM Reply With Quote
Details here
Phil
Stuart_B
posted on 25/9/08 at 03:49 PM Reply With Quote
hi, here is a picture of mine.
5
5
thanks
stuart
