Dan.
posted on 30/12/13 at 10:15 PM |
Chassis Modifications
Hi Guys,
I have decided I'm going to get my chassis re-powder coated since I am now adding a roll cage, so thought I would take the opportunity to make
some chassis modifications whilst I am at it...
The chassis is an Original MK Indy.
My plans are as follows, add triangulation to the front.
![](/galpreviews/471.JPG) ![Description](/gallery/471.JPG) Description
Add triangulation back to bulkhead unfortunately there is only room to do this on one side as turbos(yes two!)/manifold will be in the way, unless its
worth while triangulating part way as per the blue in lower pic?
![](/galpreviews/433.JPG) ![Description](/gallery/433.JPG) Description
Next Up is around the engine mounts, do you think I would be best off removing the existing triangulation front to back and replacing as per below?
this setup will have a lot of torque (will be in the region of 450bhp with torque to match) I'm aware there is noting substantial where the
engine mounts are currently located. And yes I am aware my current engine mounts are a little over engineered ha.
![](/galpreviews/454.JPG) ![Description](/gallery/454.JPG) Description
Next up when faffing around with turbo plans I removed a big chunk of my chassis... obviously this now needs replacing..
This is how it currently stands
![](/galpreviews/385.JPG) ![Description](/gallery/385.JPG) Description
What I'm proposing
![](/galpreviews/386.JPG) ![Description](/gallery/386.JPG) Description
Triangulate the tunnel
![](/galpreviews/267.JPG) ![Description](/gallery/267.JPG) Description
Move rear upper suspension pickup down wards and outwards, and remake wishbones 1.5" shorter to match, this should improve the camber issue
that's present on the original MK Indy, and also raise the centre of roll helping the car to corner flatter.
![](/galpreviews/248.JPG) ![Description](/gallery/248.JPG) Description
I will also triangulate this area but not given it much thought yet, and don't have a decent pic to hand.
Anyway if anyone would like to point out any flaws to my plan or other potential improvements
mark chandler
posted on 30/12/13 at 10:28 PM |
You only need one diagonal at the front.
Rather than add diagonals to the tunnel and bulkhead weld in 1/6" steel.
Here's mine
![](/galpreviews/2Chassis 2 April 2006.JPG) ![Chassis painted inverted](/gallery/2Chassis 2 April 2006.JPG) Chassis painted inverted
![](/galpreviews/Chassis inverted 2 april 2006.JPG) ![Chassis inverted side painted](/gallery/Chassis inverted 2 april 2006.JPG) Chassis inverted side painted
Regards Mark
Dan.
posted on 30/12/13 at 11:07 PM |
Ok so from this....
![](/galpreviews/1910.jpg) ![Description](/gallery/1910.jpg) Description
To something like this (Also moved the inner rails inwards to triangulate further)
![](/galpreviews/339.jpg) ![Description](/gallery/339.jpg) Description
Is there any reason MK have bent the lower rail so its made out of one piece rather than welding straight section?
mark chandler
posted on 31/12/13 at 12:00 AM |
You will have to ask MK
Have a read of the thesis word docs
Here
Then for the stuff I followed kitcaranalysis_V2.doc
[Edited on 31/12/13 by mark chandler]
Dan.
posted on 31/12/13 at 12:18 AM |
Thanks not seen them before will have a look ![](/images//smilies/smile.gif)
Dan.
posted on 31/12/13 at 03:08 AM |
Given the restrictions I have around my engine I have come up with the following
![](/galpreviews/2110.jpg) ![Description](/gallery/2110.jpg) Description
Or given I do not need a deep passenger foot well, and could do with the extra space in the engine bay...
![](/galpreviews/1313.jpg) ![Description](/gallery/1313.jpg) Description
If anyone would like to suggest changes attached below is a blank
![](/galpreviews/1712.jpg) ![Description](/gallery/1712.jpg) Description
[Edited on 31/12/13 by Dan.]
Dan.
posted on 31/12/13 at 03:16 PM |
No other opinions before I buy some steel and get mr angry grinder out?
fregis
posted on 1/1/14 at 12:07 AM |
not need so many diagonals, one of the diagonals in square strengthens enough, ant try "connect" diagnals.
to engine mounts diagonal are good, but enough one
Under engine i put screw reinforcement
Also put in corner (at diagonal) triangle plate stiffeners, at reduced tension of the welding seam
i have found few documents to frame stiffness optimization. email or need somewhere upload
light weights and stiff front:
how think about that?
blue one nood need- becaus engine at the point pull, other side press
[Edited on 1/1/14 by fregis]
Never be afraid to do what you are insolvent, remember: amateurs built the ark - Professionals built the Titanic.
Dan.
posted on 1/1/14 at 01:16 AM |
Cannot do the right Y brace due to the locations of the turbo's, manifolds and wastegate's unfortunately, or the cross brace as
that's where the oil tank fits and belts etc.
though you are right I probably have gone a little over the top on triangulation.
[Edited on 1/1/14 by Dan.]
mark chandler
posted on 1/1/14 at 01:31 AM |
Roll hoop and petty strut will stiffen the centre of the car
sebastiaan
posted on 1/1/14 at 10:43 AM |
Have a look here:http://locostbuilders.co.uk/viewthread.php?tid=148892 for inspiration. Made a definite improvement to steering feel.
Dan.
posted on 1/1/14 at 08:54 PM |
Thanks for the input, dismantling the rest of the car will take place tomorrow and I'll get the cutting done, hopefully my local suppliers have
what I need in stock. Also ordered a set of custom rear wishbones to match my new mounting points, I'll post pictures of progress and results of
the suspension geometry of the new bones and mounting points :-)
ashg
posted on 2/1/14 at 02:03 AM |
hey dan. good to see another saab user.
i have this brace on my car
you will have to do this to clear the saab water pump outlet anyway
or you can do this
your rear upright carriers will need beefing up, they will bend trust me!! box up the back of them and then make a hole for the driveshaft to go
through as the 3mm plate on the sides can bend.
sorry to say it if you have already spent out but i dont think your prop is up to it, i had to upgrade to a 4inch tube prop with lorry joints.
other than that great start.
couple of questions what box are you using? is it a bmw item? i went for the omega box its managed 3 years of my abuse so far!
and what are you doing with regards to dry sumping it? just running scavenge and keeping the standard pump or going the whole hog with a multi stage.
oil control can be a real issue with these engines in longitudinal format as i have found out on two occasions.
this is the wet sump layout im running now that seems to be ok, but i am considering drysump options for the future, your thoughts would be
interesting, if you dont have a solution yet then maybe we could knock heads together and develop a kit.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Dan.
posted on 2/1/14 at 02:20 AM |
Great post many thanks for replying! Water pump is not an issue as I have already modified mine :-) but will be altering the triangulation anyway.
Didn't know about any issue with the rear carriers, I will box them in as suggested though!
Did you break your prop then? What power were you running?
Gearbox is from a T5 box from a TVR, basically the same box as a cosworth 2wd ratio wise but with upgraded internals apparently, so gives nice ratios
and will hopefully last as it should be a fair bit stronger than the omega item.
I have a single stage scavenge pump pumping to the external tank, then feeding back through the modified sump to the standard oil pump, the setup is a
total doddle thanks to the sump design, did the same on a friends car and it worked a treat.
Good to know there is another saab engined car about, I only knew of one other which also was built in my lockup, where abouts in kent are you from? I
come down that way fairly regularly as I have family in Deal.
[Edited on 2/1/14 by Dan.]
Digimon
posted on 2/1/14 at 01:45 PM |
Looking good Dan ![](/images//smilies/bigsmile.gif)
Dan.
posted on 22/2/14 at 11:39 PM |
So I have done a little work on this recently....
First of all increased the size of the engine bay by eating into the passenger foot well...
![](/galpreviews/41a.JPG) ![Description](/gallery/41a.JPG) Description
![](/galpreviews/62a.JPG) ![Description](/gallery/62a.JPG) Description
Beefed up the front end with a little extra bracing and added 'r tube'
![](/galpreviews/63a.JPG) ![Description](/gallery/63a.JPG) Description
![](/galpreviews/34a.JPG) ![Description](/gallery/34a.JPG) Description
![](/galpreviews/435.JPG) ![Description](/gallery/435.JPG) Description
Decided whilst I was at it I would re-design the rear suspension geometry..... (I can never leave things alone....)
Hello angry grinder... Out with the old...
![](/galpreviews/436.JPG) ![Description](/gallery/436.JPG) Description
![](/galpreviews/337.JPG) ![Description](/gallery/337.JPG) Description
Moved outwards and downwards...
![](/galpreviews/298.JPG) ![Description](/gallery/298.JPG) Description
Decided I didn't like the contact area they had so made new...
![](/galpreviews/389.JPG) ![Description](/gallery/389.JPG) Description
Change in position
![](/galpreviews/2410.JPG) ![Description](/gallery/2410.JPG) Description
New rose jointed arms with custom shorter upper bones held roughky in place to see how it looked (thanks Danny@MK)
![](/galpreviews/1311.JPG) ![Description](/gallery/1311.JPG) Description
thought about different bracing options...
![](/galpreviews/1912.JPG) ![Description](/gallery/1912.JPG) Description
Cut all the bits for bracing and left it for my friend Adam to weld up for me.... clearly he got bored as I found this additional roll protection
welded to my car
![](/galpreviews/1513.JPG) ![Description](/gallery/1513.JPG) Description
Welded up
![](/galpreviews/1514.JPG) ![Description](/gallery/1514.JPG) Description
Mounts for cage welded in
![](/galpreviews/1215.JPG) ![Description](/gallery/1215.JPG) Description
Engine in siute, yes the manifold does fit.... just, as does the dry sump pump
![](/galpreviews/1416.JPG) ![Description](/gallery/1416.JPG) Description
Not sure what to do with the other side of the car yet, may put in a Y brace depending which manifold I use.
![](/galpreviews/1417.JPG) ![Description](/gallery/1417.JPG) Description
Anyway that's it for now, the setup should hopefully strengthen things up nicely (when the engine bay is finished) and with the rear suspension
modifications the car should roll less due to the centre of roll being raised nearer the center of gravity and the negative camber in roll
significantly improved due to the shorter wishbones and repositioned upper mounts.
[Edited on 23/2/14 by Dan.]
scutter
posted on 23/2/14 at 10:45 AM |
Looking good fella, I've just added these 2 Y braces to the front of my engine bay and a removable one across the front. Could your Oil tank
either go into the passenger footwell or drop to the level of the underside of the chassis to allow a full Y brace?
![](/galpreviews/297.jpg) ![Description](/gallery/297.jpg) Description
Regards Dan
Dan.
posted on 23/2/14 at 12:25 PM |
The oil tank is fine can position the Y brace round it, the issue is where the manifold is, I can get a y brace in there with the manifold
that's in the pic, but I'd prefer to use the tubular I have, when I get the alternator and water pump back I'll weigh things up.
Dan.
posted on 25/2/14 at 11:16 PM |
Collecting the waterpump and alternator tomorrow and have 3 days to make some progress, if anyone has suggestions for further improvements to the
chassis i'm all ears as id rather get any mods done before its powder coated... actually surprised no one has asked about the rear suspension
given The original MK Indy suspension geometry is a very talked about subject on here....
Digimon
posted on 26/2/14 at 10:00 AM |
Looking like you are making good progress mate ![](/images//smilies/bigsmile.gif)
Dan.
posted on 26/2/14 at 11:14 PM |
Some more progress today, removed my external wastegate on my tubular manifold so I could fit in a Y brace, will have to reposition the wastegate when
I get some stainless tube.
![](/galpreviews/brace 1.JPG) ![Description](/gallery/brace 1.JPG) Description
![](/galpreviews/brace 2.JPG) ![Description](/gallery/brace 2.JPG) Description
![](/galpreviews/brace 3.JPG) ![Description](/gallery/brace 3.JPG) Description
![](/galpreviews/brace 4.JPG) ![Description](/gallery/brace 4.JPG) Description
![](/galpreviews/brace 5.JPG) ![Description](/gallery/brace 5.JPG) Description
